Question...
Vikes79
Vikes79
SKOL!
10,891
105,668
South Dakota
  2. Talon X4 LV
If you rig up a wheel that you can put down on the road as your rolling that could turn a generator your movement would create power and you wouldn’t be creating green house gasses .
JTW would have to pull the EB and install a Cummins then.
320,087
Pull the fuse on the truck that feeds trailer hot in your plug. Now you'll be safe and then just reinstall fuse when you are using trailer without generator. That will keep your 12 volt systems separate.
If someone is really concerned and going that route you could easily run a fuse extension and wire in a dash switch
8101CD49 00BA 43C5 931B 805E100B2782
