G
Has anyone replaced the existing pioneer 1000 fan with a higher output fan and motor?
Thanks for looking.
Thanks for looking.
I think there is thread about replacing the fan with a Spaal unit. You might have to search for it.Has anyone replaced the existing pioneer 1000 fan with a higher output fan and motor?
Thanks for looking.
whyHas anyone replaced the existing pioneer 1000 fan with a higher output fan and motor?
Thanks for looking.
You need this!The reason I am looking for a better fan is I was working in the heat going very slow spraying weeds and the engine overheated.
Pro tip: make sure when your answering someone be sure to do it this way @golfer1 or we wont get a notice that u responded so we wont even knowThank you guys for your replys. DRZRon, the machine has less than 250 miles and has not overheated before. Everything else seems ok as well as fluid levels go. I have not run the machine with mostly just idling along with pluss 100 degree temps which is why I think a fan upgrade would be good.
Remington thanks for the help with the override switch. I have ordered the fan and switch.
Just looking at getting it all apart, doesnt look like an easy project, any hints on installation.
You guys all rock, thanks again.
I have a 2018 that had over 1400 miles of use and never overheated "until" we went on a colorado trip... needless to say the forum burp treatment fixed the problem - so do this regardless its free. Then do the override fan switch and lastly look into the ECU update (if applicable to your year) that honda tech mentions (I took a copy of the bulletin into my local dealer as they tried to tell me there was no such update) Good luckThank you guys for your replys. DRZRon, the machine has less than 250 miles and has not overheated before. Everything else seems ok as well as fluid levels go. I have not run the machine with mostly just idling along with pluss 100 degree temps which is why I think a fan upgrade would be good.
It is a 2019 1000 model.What year model Pioneer? There is a Fan Program Update for certain years to fix an issues where the fan does not operate
Thank you, I will check into it.have a 2018 that had over 1400 miles of use and never overheated "until" we went on a colorado trip... needless to say the forum burp treatment fixed the problem - so do this regardless its free. Then do the override fan switch and lastly look into the ECU update (if applicable to your year) that honda tech mentions (I took a copy of the bulletin into my local dealer as they tried to tell me there was no such update) Good luck
does your fan run?hi, need you to post pics of machine as you may be asking for a friend.....
are you sure your radiator is really really really clean? we have been down this road a few times and the pioneer radiator is on the edge of engineering efficiency - any blockage compromises cooling
also - have you had the cooling system apart at all and you sure it is totally burped, nothing blocking the fan in front\back, etc...?
Thanks, I will check on bleeding the systemYeah, you'll definitely want to look into bleeding your system @golfer1
We've seen a number of them come with bubbles in the system brand new. There are bleeder valves at the front and back of the machine, make sure you get it all right. You could just take it back to the dealer, but depending on their service department......
