P700 Rattling in engine compartment
Wingnurse32
Wingnurse32
19
7
Dutton, AL
Has anyone else noticed rattle in the engine compartment at idle and at lower RPMs. I noticed that the engine & exhaust both mount to a U-shaped bracket that's mounted to the frame. At idle the bracket actually moves back & forth in its frame mount. I'm assuming it was designed to do that. I didn't take mine back for the 100 hour service. Was planning on waiting a year to service it.
allgm1
allgm1
1,049
1,484
New Hampshire
Did you check all the clamps on the heat shields? the u shaped frame was intended to isolate the engine vibes from the rest of the buggy. why would you skip your initial service? At a minimum I would a least change the engine oil and filter, the following pic is from my dismantled filter, many have reported back finding more 20150419 161345 zpsqqcnlicv chunks in theirs than I found in mine.
swsebek
swsebek
2,854
5,835
pa
Yes he is right,Do not skip the service.Change oil-filter,and clean air cleaner.Also do yourself a favor and check the whole machine out.Take care of her and she will take care of you.
Kracker
Kracker
127
227
Louisiana
Thought it was 20 hrs or 100 miles to first service? Am I wrong?
Reactions: Joedaddy
271,883
You are correct 20 engine HOURS or 100 MILES for initial service not 100 hours.
swsebek
swsebek
2,854
5,835
pa
Im pretty sure he got the miles and hrs. Mixed up.cause if not that oil is gonna be a little dark....
Kracker
Kracker
127
227
Louisiana
Yeh thought so just wasn't around my manual wanted make sure I didn't misread, thanks
swsebek
swsebek
2,854
5,835
pa
Hey I have that rattleing,but it was my rear brakes,It quit around 700 miles or so...Im really surprised no one else didn't gripe about it cause it was loud and annoying
My rear brakes rattle so loud when braking.
I also got a rattling muffler.
I have a muffler rattle at idle. I say muffler because when I grab the muffler to keep it from shaking the noise goes away. It probably could be a lot of other things
SundayRdr
SundayRdr
575
1,179
McMinville Tn
I've had a "growing" rattle on my 700-4. I found a nut laying on my trailer one evening when unloading and didnt where it went and I've had a constant rattle for a while. I found the 2 bolts behind the seat back that bolt the cage together had came loose and rattling. Replaced the nut that came off which I had lost and tightened the other one and no more rattle. 2016 03 17 214321
Rvon
Rvon
7
Spokane, WA
I had a rattle sounded like it was coming from the engine compartment. It was the door. But then again I'm really darn near deaf.
Reactions: Farmer
