P1000 Real Tools Required
What style tool kit best fits you?
  • Pioneer specific kit
    Votes: 18 18.8%
  • Reasonable tool kit that should fix most everything
    Votes: 56 58.3%
  • Tool kit for everything I can possibly imagine
    Votes: 22 22.9%
  • Total voters
    96
Neohio
Neohio
Beast of the East
21,740
93,120
Painesville Ohio
I'm curious if anyone has put together a list, or started a list of the actual tools needed for the pioneer. For the sake of a trail kit. Granted you may need tools for other machines out there but I'm thinking if im on a long trip and want to save weight and space what do i need specifically for the Pioneer 1000. For instance I know I need 10 and 12mm, also the steering stem nut is a 19mm. Is there anything thats 14,15,16 or 17mm? What tools are needed on the ball joint?
Take a second to vote if you would please!
The goal of this thread is to provide a precise list of tools one would need to fix their Honda Pioneer on the trail.
I'll continue editing the list below
Sockets:
10mm body bolts
12mm
14mm
17mm Tie rod ends
19mm Steering stem
21mm Tapered lugs
22mm Standard lugs
30mm Axle nut
Wrenches:
1 1/4" open end wrench or crows foot for inner tie rod end.
Allen:
5mm for air box?
5 or 6mm for engine cover panels
14mm is the hex size on inner tie rods for setting toe.
5mm hex for airbox is confirmed.
5mm hex for body panels is confirmed.
Stock Honda Lugnuts are 19mm
Aftermarket hex nuts like @JTW runs are 17mm (Maybe he can confirm?)
1/4" or 5/16" (6mm/8mm) for Heater hose clamps.
Torx 50 for upper seatbelt bolts. (Confirmed 1/22)
5/8 for seatbelt lap bolts. (Confirmed 1/22)
Although I doubt you will be doing trailside repairs on seat belts.
10mm 5 bolts holding front seat back in place.
10mm on door hinges, all nets held in with 10mm
Kilo427
Kilo427
1,543
6,441
Yes knipex cobra plier and the plier wrench are a fantastic tools, also I agree with the plastic rivet tool when you have have to tear everything down they are very handy.
Neohio
Neohio
Beast of the East
21,740
93,120
Painesville Ohio
Reactions: Ragnar406 and sharp
I'll keep updating the list. I'll break it down into a "absolutely necessary " list and an "optional" list
This was a really good idea and useful to even some that have experience bringing things!
There’s been the same question several times but if someone followed every post you’d be going up the mountain pulling a Snap-on truck. To update the the list into two categories with input from this group is a great thing. Great thread idea!
Neohio
Neohio
Beast of the East
21,740
93,120
Painesville Ohio
I didn't list a single Snap-on item!
I did link some Williams wrenches though. But they are dirt cheap in comparison.
Well I didn’t necessarily mean specific brand name. Just meant it’s nice to have the right tools for the job and not bringing a ton of useless stuff. With a good list from people in the field someone can narrow the tools down with just the needed items. A ton of tools is useless if they don’t work on the application
Torx 45 or Torx 50 for upper seatbelt bolts. (Will confirm tonight)
7/8 for seatbelt lap bolts. (Will confirm tonight)
Yup these 17mm are what I’m running on the STI original beadlocks
ITP Tapered Chrome Lug Nut
289E5DE1 C4C4 42FB AE8F 7FBF8B69C7E6
Reactions: Neohio and sharp
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,231
Oshkosh, Wi
Has anybody found a pelican type case that fits inside the rear doors yet? That would make a nice tool box storage location
