P1000 Real Tools Required
What style tool kit best fits you?
  • Pioneer specific kit
    Votes: 18 18.8%
  • Reasonable tool kit that should fix most everything
    Votes: 56 58.3%
  • Tool kit for everything I can possibly imagine
    Votes: 22 22.9%
  • Total voters
    96
Has anybody found a pelican type case that fits inside the rear doors yet? That would make a nice tool box storage location
@joeymt33 has
Not positive on sizing but the Harbor Fright boxes are bad ass
Reactions: Neohio and sharp
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,231
Oshkosh, Wi
Neohio
Neohio
Beast of the East
21,740
93,120
Painesville Ohio
For reference, I'm not just asking for a hand out. I did buy the smallest Harbor Freight Apache case and it turns out it's pretty nice but doesnt fit under the glove box or in the door. I'd like 1 for tools and 1 for camera's and phones.
1800 Weatherproof Protective Case – 9-3/16 In.
Sounds dumb, but how did it not fit?
Could you open your door hole larger? Or it went in the door and sat funny and wasted space?
Did you use a hole saw on your door? Or body saw and cut out the weirdly shaped opening?
I have a Storm im2050 case kicking around. I will see how/if it fits.
9.5x7.5x4.3"
Reactions: sharp
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,231
Oshkosh, Wi
It's thicker than the distance from the inside of the door to the outside. I think it would fit near the hinges but you'd have a cut out larger than the exterior panel by the time you got it in there. It it was 3/4" thinner between the top of the lid and the bottom it would probably sneak right in. Likewise if it was only 7 or 8" long it would tuck behind the net of the under dash storage real nice.
Neohio
Neohio
Beast of the East
21,740
93,120
Painesville Ohio
So we need to find something less than 4 3/8" Tall?
Capture34
I thought he was running dry bags?
I don't have a large enough Pelican dealer around me to drive my machine over to test fit cases.
Shoot I thought question from Todd was asking for space next to door under seat down. You are right my apologies
Neohio
Neohio
Beast of the East
21,740
93,120
Painesville Ohio
I would guess in the 3.5" range. I'll grab a few photos later this week.
Pelicans website kinda sucks.
You can search based on interior dimensions.
We might be stuck with their "micro" line of cases. I'm not sure how much confidence one will have in them, or how much they will hold.
Edit: Pelican 1120 or 1170 might fit.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I can always get behind the use of pyrotechnics
Cross headed fasteners.
Do not use your regular Phillips screwdrivers on these. You will strip them and frustrate yourself! The Japanese use their own style cross headed fastener. They were at one point referred to as JIS #1,#2,#3 etc.
I believe they are now referred to as "Plus". Most of the bed screws are a #3.
You might want to invest in a hand impact driver and some specialized bits.
Vessel Hand Impact Set
If you have an impact driver, you can purchase just the bits.
Impact Bits
If that is still of little interest to you. Check out this screwdriver. It has a built in mechanism to twist the fastener when hit with a hammer.
Impacting Screwdriver
If you end up getting a hand impact screwdriver, you will need a hammer with some heft to it.
After stripping out a few screws and ordering that Impacting screwdriver on your recommendation I can vouch for it... it works great -
Neohio
Neohio
Beast of the East
21,740
93,120
Painesville Ohio
I ordered an 1120 and 1170 from Amazon. I will report back this weekend on whether either fits.
Is a pop can good enough to determine scale?
Reactions: sharp
MMW
MMW
59
111
Arkansas
I'm curious if anyone has put together a list, or started a list of the actual tools needed for the pioneer. For the sake of a trail kit. Granted you may need tools for other machines out there but I'm thinking if im on a long trip and want to save weight and space what do i need specifically for the Pioneer 1000. For instance I know I need 10 and 12mm, also the steering stem nut is a 19mm. Is there anything thats 14,15,16 or 17mm? What tools are needed on the ball joint?
Take a second to vote if you would please!
The goal of this thread is to provide a precise list of tools one would need to fix their Honda Pioneer on the trail.
I'll continue editing the list below
Sockets:
10mm body bolts
12mm
14mm
17mm Tie rod ends
19mm Steering stem
21mm Tapered lugs
22mm Standard lugs
30mm Axle nut
Wrenches:
1 1/4" open end wrench or crows foot for inner tie rod end.
Allen:
5mm for air box?
5 or 6mm for engine cover panels
Cuoutdoors, I am glad you started this thread. I am planning a trip to Colorado next fall. I had been thinking on what to take as far as repair items. I wonder if you could expand the list to include what a person should carry for going out of state and up into the mountains, Thanks!
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Yes this has been evolving. I think we will end up with 3 or 4 lists total starting from bare minimum and going up to overland adventures.
