P1000 Real Tools Required
What style tool kit best fits you?
  • Pioneer specific kit
    Votes: 18 18.8%
  • Reasonable tool kit that should fix most everything
    Votes: 56 58.3%
  • Tool kit for everything I can possibly imagine
    Votes: 22 22.9%
  • Total voters
    96
Yeah.. I have a small plastic 5.56 ammo can that will fit. And then I stuff either water or straps and the such in there. It’s a great place for a couple gallons of extra bottles of water..
I use one side for trash. That’s works ok. Would be better if it didn’t all fall out when I open the door
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
Reactions: sharp and BWAF
Thanks for the pics - I did try again saw that it would work.. you must have removed or done something to the seat back part that flips up - Looked like part of it rested on the top of the pelican case.. I did not mess with it except to see that I could get it to fit
I don’t think so? Maybe pelican slightly changed the box? I could have done something and forgot though
Reactions: sharp, BWAF and JTW
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I just went and took a couple pics of how the seat folds on top of the case - I can push and get the seat back down enough to shut the door but there is some tension there. You can see the ledge to the right that the seat bed plastic is suppose to rest on
D3A94A9B 21FE 4EE5 9AD2 2CB4A4766B22
3D603F71 983A 47D8 B1B5 C80277FC6893
That just keeps it from rattling. I usually have my rear seats out anyway. And if the seats are installed I have the cushions out because the kids car seats strap down better with the cushions out.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Ok gents i've updated the list again. Let me know what i've missed, what i need to fix, any other changes you'd like. Thanks for all the help putting this together.
Reactions: sharp and joeymt33
Fastbuck101
Fastbuck101
57
91
New Mexico
Has anybody found a pelican type case that fits inside the rear doors yet? That would make a nice tool box storage location
Harbor freight has a small pelican type case that will fit in there, but you have to take off that plastic cover that sits over the oil dipstick- Doesn't seem to serve any purpose. you also need to remove the lower seat cushion to lay the seats flat.
Reactions: sharp
ToddACimer
ToddACimer
Pioneer 1005-2
3,811
16,230
Oshkosh, Wi
I'm talking about inside the rear doors not under the seats.
In here
IMG 20181117 111000
Neohio
Neohio
Beast of the East
21,739
93,107
Painesville Ohio
Here is a little Pelican. It was a bit of messing around to get it to go in and slide next to hinges.
I don't recall the # off the top of my head. I had to open the hole way up to get it in.
1400 fits under the seat I believe. But you need to lift bed to access unless you remove the cushions.
Edit, Looks like a pelican 1120.
IMG 20190202 1144034
IMG 20190202 1142586
IMG 20190202 1139237
IMG 20190202 1142279
IMG 20190202 1139415
