P1000 Rear pod light wiring
bowhunt716
12
10
West Virginia
Hello, how is everyone running the wires from the dash rocker switch to rear mounted pod lights? Are you all running it under floor and seat or up the cage and around roof?
67,230
Ya
Follow the main wire harness from under the hood inside passanger wheel well. Under the floor board. Up by gas tank and across to driver, then to the rear.
I go up pillar B then to the rear along ROPS.
You could also go up at gas tank behind passanger and to your location from pillar b.
Reactions: TripleB
Pilotadam
Pilotadam
326
735
Pell City, Alabama
I did the same thing. I made my run first with a string and then marked were all my branches were going to be for different components. I then pulled the wire and taped it all together to create my own wire harness. The section the runs up the cage I put heat shrink own to make a clean appearance and hopefully reduce it getting caught by branches.
9243e0dbca70711e2552e0c7732cf04e06201eee9933f741c319a2e614166fd9693007c6981cca93311590b488f92499
P
PioneerDuluth
26
53
Duluth, MN
s
View attachment 173639View attachment 173640View attachment 173641
Same, and same. You'll have full access to the underside if you take your skid plate off. I ran three sets of wire for my rear light pods and and other future accessories as well.
Reactions: hawgsooie
bowhunt716
12
10
West Virginia
Thank you all for the info. Trying to use the wiring harness that came with the Nilight brand lights. Appreciate all the help.
