Let us know how this works, Ive done all the heat shielding I can come up with, it all helps , but I'll probably go fan.View attachment 84478 View attachment 84480 View attachment 84481 View attachment 84479 View attachment 84482 View attachment 84483 View attachment 84484 View attachment 84485 View attachment 84486 View attachment 84487 View attachment 84488 View attachment 84489 View attachment 84490 View attachment 84491 View attachment 84492
started with a 15 x 20 piece of plate and cut a 7 x 10 triangle out of the lower left corner.. I used that piece to weld underneath. I have a break, but a sturdy table and some angle iron will let you do the same thing. Put everything back together this afternoon, looks like it may work for the rear passenger floor. Wondering if the 3's have the same degree of heat problem as the 5's? Haven't seen one, but you might could make this much bigger on a 3 and really knock down some of that heat. Will let you know how this works as soon as I try it out, maybe this weekend.
