rear shock guard
MDFMac
135
240
upstate ny
so i don't understand why this faces forward. my rear tire throws dirt and mud on the rod of the shock. so i turned it around and now its mostly clean after a ride.
this pic is not my machine.. just a quick google grab for reference.
2021 Honda Talon 1000X FOX Live Valve 4
Reactions: Mudwing and Isaiah
That’s a great idea! What was involved in that?
MDFMac
135
240
upstate ny
take out the lower shock bolt.. twist the shock 180 and reinstall bolt... but i also installed shocktherapy springs
Reactions: Montecresto and CID
5,485
25,246
I saw these on TerryH's build thread and liked them. Shock Therapy doesn't recommend shock covers because of potential heat issues but they're desert racers and I'm not Ricky Racer, have a high degree of mechanical sympathy and couldn't stand the chromed shafts and soft rubber seals being exposed to all the debris thrown up by the the tires.
Photo thanks to TerryH -
I qBwp4vJ L
Rednick69
Rednick69
154
1,260
White Hall, AR.
After riding for a while I have a squeak in my shocks. I splash some clean water on them and it stops for a while. Do you reckon covers like these would help with this issue?
Reactions: Isaiah
5,485
25,246
No, I don't. I 'think' suspension squeak is caused by metal rubbing on metal, either the spring against the shock body or the spring ends twisting on their seats; shock covers won't help with that (if I'm right). A test would be to hit those surfaces with WD-40 BUT that will attract dust so you need a dry lube of some sort. I'm not familiar with that type of product so I can't recommend one but they do exist as far as I know.
Reactions: Isaiah
PaulF
PaulF
1,462
4,815
Shock covers came with my Weller Racing re-valve. I thought they were a gimmick but after having them on for a while, I wont own another dual spring shock without them. I change my crossovers sometimes depending on what type of riding (soften them up for crawling and crank them up for the dunes) and without the covers, it was a chore to get the rings moving. With the covers, they turn with one finger, even after a dusty day's ride.
They also keep the dust/sand from collecting between the plastic spring separator and the shock body. This dust/sand collection has gouged up my shocks pretty good and has caused them to stick in the past.
Reactions: Isaiah and CID
PaulF
PaulF
1,462
4,815
And about the plastic guards. They are not there to keep the dust/dirt/mud off, they are intended to keep the little pebbled that bounce up from the front wheels from dinging your springs and shock rod as you go fast down a trail. Little dings on the springs weaken them and tiny dings on the shock rod will cause the seals to start leaking.
To illustrate, all the forward facing surfaces of my lower suspension parts in the rear have little tiny dings on them but none of the rear facing ones do. Once you get enough miles on your machine, you will see what I mean.
