P500 Remi’s P5 Bumblebee Build
Deleted member 3748
Also tidied up SOME wires the ones on the back side, don’t look at those lol. I’m going to make a switch plate for a few more things and I’ll take care of those buggers.also added a few fuses to the leads off accessory harness. I added a ground bar as well. Still need to run acable to the frame or just leave it haven’t decided. It has 2 heavy screws into the cross member that will make a nice ground. View attachment 79735
Are the four heavy cables for the winch relay? If yes, there is a factory relay mount point on the upper passenger side. That's a clean install, but you may want to know about that for future plans.
107,347
I wish you had asked me about the half windshield. The half I use allows me to open the hood without removing it.
I never even gave that a thought. i have the Honda on my P1K5 like it and have luck with it so I got a smokin deal on this one so i just went with it. its 2 manual honda clamps and it s loose or off. 10 times easier than my P1. in fact, everything on this P5 is easier than my P5, its like working on a 80% efficiant std furnace than a 90% variable speed.
107,347
yes i believe so, im not out there right now to look at it. it is on the passenger side. it was already done when i bought it. im still going threw the wiring that was done, very tedious work :mad:
Deleted member 3748
They did a good job. Just letting you know Honda provided a place for that relay.
320,492
Thanks CP, she’ll be dressed up like the P1 in no time. Not quite the beast the P1 is, but Fivel (the wife) will be happy;)
I’m positive of that!
Reactions: Remington
107,347
My other gas can arrived. Looks mint! I like.
107,347
This came today also. The cord for the Boss Rebel was to dam short! So I looked on the Boss sight and no help. Called there technical support and they didn’t know there butt hole from a hole in the ground. So good old Amazon, I started looking at cable and pics and took a gamble for what I thought would work! 6$ and 10’ cable came and holy hell it worked! Bingo!
107,347
Got that machine looking good and equipped, pretty damn fast too. Definitely need to check out the Gladwin trails, some of them are super tight and you'll see where that Bumblebee shines. ;)
right on! soon my friend soon:cool:
Reactions: tr005 and trigger
