P1000 Removing sway bar
Have you removed the sway bar on you 1000/1000-5?
  • Yes
  • No
  • Not yet but going too.
Results are only viewable after voting.
DDDonkey
How may people have removed their sway bar on there 1000/1000-5? I need to adjust the camber on my rear a-arms and am trying to decide if I should remove it while I'm in there. I am only thinking about it since I have my new 814 shocks on it, and the Taylor park trip coming up. I do a lot of black top riding, but when out and about, really like the technical slow stuff when I can find it. Please vote.......
Landman
Landman
The Great Bearded One
594
2,410
Central Arkansas
Removed mine last year... if I’m going to be dirt road/blacktop riding which is typically just riding back roads to my parents, I try to remember to set the Fox shocks on firm to make up for the lack of the sway bar - it helps a lot. The first time I road over there and left them on soft, you could really feel it on the curves.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Pull it! It make it articulate much better... like landman said if you gonna ride alot of asphalt bump the shocks up to firm.
When you pull it take it out the driver side...make life alot easier.
Bradley-Thornton
Bradley-Thornton
684
1,649
Hattiesburg MS
Why do you remove it????? I can't believe so many have what am I missing???? Does it make it ride better, softer???
Reactions: CumminsPusher
Rough terrain the suspension is completely independent. Machine stays more stable.
High speed she's a little loose but I don't run high speed very often.
Tigermark
Tigermark
Outside looking in.
You can disconnect it and zip tie the ends out the of the way and drive it around and see how you like it. If so, then you can completely remove it!
322,690
My opinion is if someone is mainly asphalt leave it in, it can give an unsettling feeling at first till you get use to it but like the guys said shocks can be adjusted to make up for it some.
Off-road it’s just night and day. Articulation is nice to have, why let an independent rig act like a solid axle. Way better out, smoother and much better traction. Extreme side hill it’s a little better attached but everywhere else in the dirt it’s worth having gone.
Even high speed dirt road you get use to setting the machine up for the cornering and can probably run faster without.
BigOL3
BigOL3
2,994
8,920
I had been wanting to, but just never did until I added the 814's a couple months ago. With the wheels and shocks off, it made it too easy to resist. I left the bar, just undid the attachment.
I did not buy a Pioneer to ride the roads, strictly an off road machine for me.
Outacntrl
Outacntrl
111
326
Kansas
I removed mine and couldn't really tell a stability difference on road. Definitely articulates better in the rough stuff though.
drfubar
drfubar
TheDonFather
5,889
19,242
Mary's Ridge (Dayton Mtn), TN
I was a "holdout" for a long time because it just feels better with it in but mine's been out for almost 2 yrs now and I'm glad I did. Like said above if you drive more level areas, leave it in... if you are more in the off road fun areas...take it out. And to those that are about to say, "I told ya"! Y'all can kiss my ass. :rolleyes:
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I'd never consider putting mine back in. Tires stay planted so much better without it. As for street riding, I honestly can't tell that much difference. The road from home to work is one curve after another.
Ohio4x4
Ohio4x4
I brought the dishwasher
1,528
15,413
Ohio
I just pulled mine and wow. I wish I had done it sooner. I do ride quite a bit high speed on roads around the house but for the gain in flex i can deal with the small amount of sway. I wont be putting it back on.
Leukic
Leukic
314
995
Leesville, South Carolina
How hard is it to remove? I do ride black top some around my house but not 50plus mph. How much of a diff does it help in technical rock climbing and all?
Reactions: TripleB
Ohio4x4
Ohio4x4
1,528
15,413
Ohio
It took maybe ten or fifteen minutes to pull it. I took the left rear wheel off then the lower side of the shock. I unbolted it and pulled it out. I did have a second set of hands when untangling it from the machine and it made it easy. As for the technical rock crawling I cant say for sure I am in ohio. I don't get much of that on the home turf. I played in some usual areas where I need 4x4 to climb out of a creek bed and it did it in turf because of the added flex allowing both rear tires to be planted. I did run it 50ish miles at 40-60 mph on and off road to see how it would affect my day to day uses and while it does sway a bit more it's still plenty stable for high speed road use and running in the fields around the house.
Reactions: Leukic
Leukic
Leukic
314
995
Awesome I will be pulling mine tomorrow then.
Reactions: Delton and Ohio4x4
