That's a high quality battery that comes from the factory - it shouldn't be dying already. Maybe you have something draining it with the ignition off. Got any accessories that might be doing that?My 2016 battery seems to be dying. Do I go to the dealer or is there a lower cost, high AH replacement that fits?
Thanks, ghost. That's good info on the battery.
After thinking about it, I think the battery is suffering from the machine being run for short trips and not enough to completely recharge the battery. I have several additional accessories (lights, ham radio), but they are on a secondary battery with an isolator. After jumping it off yesterday and running it I feel certain it just needs to be run longer. I have a voltmeter on each battery and the main one is holding a charge now.
Really? What's wrong with you? HA! These things are made to ride all day long!I had a boat with a big system in it. I had to buy a battery charger/ maintainer to make sure the batteries stayed charged well worth the money being the price of the batteries aren't cheap. same problem with the short trips.
Mines a 2017 deluxe. Another perk for the le I guess,lol.Battery Tenders are the way to go if you have a battery that will be sitting for a while.
My P1K -5 LE came with a port for the tender
Under the hood?Battery Tenders are the way to go if you have a battery that will be sitting for a while.
I think dealer installed. I will check my wiring diagram for 18’s to see if it is there. But i doubt it.I have a 5LE too. Where is your port located or was this something your dealer installed?
Here is the port:Please give more details. Is the BT permanently installed on the machine? Is that a 110v line going directly to an outlet? Which BT model?
Pretty sure it's this one:
https://www.amazon.com/gp/aw/d/B000CITK8S/?tag=sxsweb24-20
