P1000 Riding shotgun with DrShotgun
DrShotgun
DrShotgun
3,907
47,888
Southern Ohio
Today I finally got my skid plates and a arm guards installed from S&S Fabrications along with removing my sway bar links. I left the sway bar in for now and just removed the links, but if it get noisy I will remove it all together. I thought I’d leave it in for quick reinstall incase I need to warranty anything.
FF528E9C CC08 4424 A396 69EC1CDE1E8C 6ECE3C1C 2346 4D91 9AB7 B2DF97F87597
DrShotgun
DrShotgun
3,907
47,888
Southern Ohio
Well I have some rides coming up so
I’m taking a break from working on the house and back to working on the machine. I did the heat protection first. I just used a car windshield reflector. We will see how it works.
73270222 ABA9 494C 811F 41FC51880149
DrShotgun
DrShotgun
3,907
47,888
Southern Ohio
I also did the rear door storage mod on one side. I will do the other later but two of the Allen heads were trying to strip so I might have to drill them. I’m using the storage in that door for a large tow strap and tree saver. I also put a couple ammo cans under the front seat. One has a few tools and the other has a 12volt pump, tire plug kit, and sidewall slugs.
9FC2B508 80A9 4286 9FC8 AA4FA9332E18 388B2EC1 A9BC 4020 9048 9F7D701DDDFB
DrShotgun
DrShotgun
3,907
47,888
Southern Ohio
I put on the rough country bumper panels with built in LEDs and their twin light bar set up that connects to the fairlead bolts. If you are doing this do yourself a favor and get a nutsert tool to insert them. I did it the old fashion way with a wrench and socket, but the other way will save significant time. Also I suggest having a good step bit if you have to make the holes in the bumper panels a little bigger to line well with the nurserts. A little massaging was done on my end to make it all fit and the washers supplied in the kit covered my tracks. Both of these light bars came with switched but I tied mine into a high beam switch from the club store. Pull off their switch cut yours wires to length and wire black to black and blue to red. Just tape up the white wire it isn’t needed.
367836A7 FD59 4FCD 823C EE3E6A3D3AB0 5C12BEB4 BBC4 4B8F 8BF4 91B21283A2CF
DrShotgun
DrShotgun
3,907
47,888
Southern Ohio
I also did like many others on here and did the through the hood snorkel. I went through my brother in law’s scrap pile and took a piece of 3” exhaust aluminized pipe and painted it with header paint. We will see how it holds up. If I change my mind it’s just another stop by the scrap pile.
DC3663B1 8212 4B6D 9938 9881EDE845A2
Montster
38
66
I am very curious an interested in the system 3 xtr 370 tires you put on. I am thinking about going with those myself. How do they do in the snow compared to the oem bighorns? Also how do they do on hilly terrain and trails compared to the oem bighorns?
Reactions: BrianN
DrShotgun
DrShotgun
3,907
47,888
Southern Ohio
They have went through everything I’ve thrown they at so far. Over a foot of snow was no problem, and I have done some steep black trails with them with now problem. They have rubbed a few times on downhill off camber while turning, because they are very true to size but nothing I can’t live with. I think you will be pleased with them I have been.
Reactions: BrianN
Honda_Dave
Minnesota
Do you feel any loss of power throughout the powerband with those tires?
Reactions: Isaiah
