P500 ripsaws on order
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Well after weeks and weeks and weeks of research and pondering and many many beers later i pulled the trigger on 26" ripsaws i stead of 27" bighorns only because of the negitive feedback in snow and mud from the bighorns i just wish the ripsaws came in 27" oh well with in 2 weeks ill have a great wright up on them good or bad you guys will hear how they are on our p5s cross fingers and wish luck
Reactions: p500fan
Moose308
386
289
She should pull hard with them .Should be ni ght and day.Waiting for report. They look like great tires.
Reactions: p500fan
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Next order is terra 45 with syn cable then itp beadlock rims ;) seeing how im playing the waiting game with hmf and shock companies :(
p500fan
p500fan
418
358
Sand Point, AK
While I congratulate you on your purchase of Ripsaws, I am a little confused about your statement that they are not available in 27". I have a set, and they are wonderful. You should be pleased.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Even on sedonas website the biggest size is 26"
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Nm they are available in 27s but on 14" rims im sticki g with 12"
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
@p500fan how much of a difference are they from stock???
p500fan
p500fan
418
358
Sand Point, AK
Oh, I'm sorry. I forgot about having to go to 14" rims to get the 27" tires. To answer your question on performance, it's about like a puppy and a dinosaur. Ha! I gained almost 2" in ground clearance, it feels like I put power steering on it, & the 11" wide front tires float over the mud, without digging in. It did widen me out about 3.75", but I can still fit down the existing 4-wheeler trails. When I'm on pavement, the tires track straight, and don't "side roll" when cornering. Also, in spite of the aggressive tread design, they ride smoothly. I'm totally sold on them. Have not regretted buying them for a second.
p500fan
p500fan
418
358
Sand Point, AK
They also run very close to stated size. Actual diameter is 26.875", and actual width is over 10.750". This is mounted on 14"x7" wheels.
p500fan
p500fan
418
358
Sand Point, AK
I think you will be very pleased. In fact, if I were to change anything, it would be to drop down to 26" diameter. There's not much clearance with the 27"s. I didn't have to do the frame mod, but it's close enough to make me wonder. I haven't "rubbed" yet, & probably won't, but I only have about a half inch to play with.
Code54
Code54
583
626
Hurricane West Virginia
Once you run them for a while please let us know what you think!
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Well i cant really say that for stockers they have held up pretty good considering they are the same as the rancher 420 stock and i have never had a flat "knock on wood"
hossman55
I have 26's ripsaws & they go good in mud & up loose rocky steep climbs here in eastern Kentucky. They're also good for the off camber hill climbs good stiff sidewalls.
p500fan
p500fan
418
358
Sand Point, AK
hossman55 is right. The stiffer sidewalls are a real plus to the handling of the machine. Ripsaws aren't as popular as some other tires, but everyone who has a set up here in AK swears by them. They have given me everything I asked for, and more. I know of 3 other rigs on the island who are running them, and have heard nothing but good about them.
Reactions: jak9922
