Rodents.... damn rodents
Mudwing
Mudwing
36,959
306,672
The Mud holes
1303CCD3 6316 42F3 965D 4239A640013D
I just made this using 3/8” all thread, nuts, washers, 1/2” copper tube inside of 3/4” copper tube and wood for the ramp. I don’t have mice eating my wires, but they do occasionally get into my house. I set traps normally, tonight I’m trying this.
Vikes79
Vikes79
SKOL!
12,063
115,877
South Dakota
  2. Talon X4 LV
View attachment 103256 I just made this using 3/8” all thread, nuts, washers, 1/2” copper tube inside of 3/4” copper tube and wood for the ramp. I don’t have mice eating my wires, but they do occasionally get into my house. I set traps normally, tonight I’m trying this.
Looks good!
How easy does the tube roll?
For it to work it needs to roll very very easily.
Mudwing
Mudwing
36,959
306,672
The Mud holes
Looks good!
I put the 1/2”inside the 3/4” and then the all thread. Reamed the ends and put washers on the end. It rolls very easy. I drilled the ramp so it sits on the end of the all thread tight. I’m gonna set it up tonight, I’ll let you know the results.
212,778
I'm impressed, type L copper! HA!
21,764
93,366
Throw some anti-freeze in the bucket and a drop of soap to keep them from smelling.
Mopower58
Mopower58
Unburdened by what has been!
88,349
755,980
Crystal Springs,Ms.
Between ours and the neighbors cat we don't have a mouse problem. The tractor has no problem. They love the barn where we keep hay and feed for the horses,that is where you will usually find the cats. Ours will leave dead mice and birds in front of the stove. She uses the doggie door to go in and out. Neither of our dogs bother her.
21,764
93,366
What solution would you use? All propylene glycol with a few tablespoons of dish soap?
Water is usually fine, but these temps...... Might not drown them!
Just use a couple inches of antifreeze. Even RV stuff that is $3 a gallon will be fine. The soap just helps the surface tension and makes it slippery.
Reactions: sharp and Mudwing
21,764
93,366
Any takers?
Reactions: sharp
212,778
I use PEX, my days of soldering copper are long gone lol.
Use use PEX on projects that we don't have to be concerned with volume. The PEX fittings are restrictive.
