Hi all,
Been looking into buying a 2 gallon gas tank from rotopax. Any comments good or bad?
My dad has a kolpin roto pax style gas can. I borrowed it last year and there was a pinhole leak in one of the corners. I roughed the area up with some coarse sand paper. Cut a strip of plastic from a jug of windshield washer fluid. Laid the strip over the hole in the tank and heated it up with a heat gun. Kinda worked it in with a flat screw driver. It never leaked during our trip to west Virginia that week and has been good ever since. Zoom in on the bottom left corner of it and you can barely see it there.I learned the hard way about venting. I had one mounted on the back of my SxS and let it sit in the hot sun one summer afternoon in Nevada and an hour later as I walked behind the SxS I was sprayed with a Gasoline mist coming from a rupture near the center of the container. I emptied it and have not used it since because I'm afraid that it will continue to leak and with gasoline as expensive as it is right now I can't see taking a chance and wasting precious fuel. Does anyone know if the plastic can be patched ?
I kick myself everyday for not buying the big ATV rack sized Kolpin one. They had an open box one at Sportsmans Warehouse for like 75% off, but I talked myself out of it at the time because I only had the Rubicon and didn't want that huge tank on the rack. Would have been awesome in the Pioneer....The last time I looked, koplin fuel paks seem to have been discontinued. Mine has been great, and I'm sure the roto paks will be equally as good. You can't use them on a Polaris, though
I actually bought mine for the front rack of my old 450S.I kick myself everyday for not buying the big ATV rack sized Kolpin one. They had an open box one at Sportsmans Warehouse for like 75% off, but I talked myself out of it at the time because I only had the Rubicon and didn't want that huge tank on the rack. Would have been awesome in the Pioneer....
