Roto Pax
GRANITE
GRANITE
People Dying to come see me!
1,129
5,760
Brookville, Indiana
I actually prefer the smaller 1 gallon-3gallon containers versus the larger ones. easier to fit places and stack where the big ones are much heavier and bulkier to handle.
182,278
That was my thought too but then I had to buy two of their mounts and they're not cheap! 🤑
crewcabrob
crewcabrob
1,029
4,039
Omaha
I thought about two containers vs one large one. Rarely would I ever need the 4 gallons that the large one holds, but it seemed better for a couple of reasons.
First, the weight of the large one is less than two smaller ones. And you still have to add in the weight of two mounts.
Second, the expense is way higher for two Rotopax and two mounts than one single.
Lastly, if I have run my gas tank down close to empty, I really only want to deal with filing the tank back up one time.
I agree that it is large and convivence of the smaller Rotopax would be nice. For me, I made the compromise to get the large one. And it fits really well against the ROPS on the 520s.
20211001 223444737 iOS
5,492
25,269
Because I couldn’t get my Rotopax to completely tighten without using a wrench (the detent bumps are too tall, I think), I used a ratchet strap to keep it from moving (movement causes wear). Now it’s a PITA to remove so I carry a siphon hose to transfer and never remove the RP. The hose is 3/8” and I push a bolt in each end so it doesn’t fill with dust. It’s also clear so I can see the fuel before ingesting any.
It’s takes a bit longer but I’m smelling the roses, it’s not a pit stop for me.
F
Fyathyrio
245
675
There are a few 3D printed wrench options for the cap, I use this one. I also designed one for the slightly smaller water jug caps.
I just wish somebody made a solid cap for the fuel cans that didn't require the nozzle as part of the seal. I hate having to pull the fuel covered nozzle out and having hands that smell like gas the rest of the day. I would prefer to store the nozzle elsewhere on the vehicle.
WagginTail
WagginTail
1,585
5,880
SC
Funnel?
WagginTail
WagginTail
1,585
5,880
SC
My dad has a kolpin roto pax style gas can. I borrowed it last year and there was a pinhole leak in one of the corners. I roughed the area up with some coarse sand paper. Cut a strip of plastic from a jug of windshield washer fluid. Laid the strip over the hole in the tank and heated it up with a heat gun. Kinda worked it in with a flat screw driver. It never leaked during our trip to west Virginia that week and has been good ever since. Zoom in on the bottom left corner of it and you can barely see it there.
Here's a better pic of my repair. Doesn't look great but held up great. Was my first time repairing plastic like that
20220430 130411
20220430 130420
Bad_bowtie
Bad_bowtie
Huge member
2,549
15,704
East Tennessee
I copied @ToddACimer a couple years back and it has worked out pretty good so far. Easily removable if I need the bed space and folds up against the tailgate if the back seat is up.
stellarpod
stellarpod
821
3,024
OKC, OK - USA
I think CID (and I) would like to see a wrench for tightening the mounting wings, as it gets quite difficult getting them tight enough that the cans don't move - especially on brand new cans.
Steve
5,492
25,269
Steve
Not positive but I think the upgraded wing set takes care of that. There are two sets of wings, one to locate on the locking bumps and the other to tighten.
5,492
25,269
Steve
This video shows that the Deluxe T-handle ($24,95 but $35.20 for tax and shipping) will make complete tightening easier, not having to force the single handle past the bumps in the plastic.
Link -
Reactions: Buggyman
stellarpod
stellarpod
821
3,024
OKC, OK - USA
Link -
Actually, I already use the "deluxe" mounts. They're definitely easier, but it's still a bit of a challenge to get them really cinched down.
Steve
  • Sad
Reactions: CID
