Safe-Xtract Winch Line Lock
Bighat
Bighat
875
3,737
Gallipolis Ohio
Anyone use one of these for shorting winch line? Here's pic:
1650933503477
Bighat
Bighat
875
3,737
Gallipolis Ohio
I have an email into the company that sells these because I can not find any information about how to rig the tool and line. It's rated and 20,000lb. It's suppose to be a safe way to short a winch line but I can't find any details that's why I thought I'd ask around.
Bighat
Bighat
875
3,737
Gallipolis Ohio
The same company makes this one, seems easier to understand.
The one you posted..uhm...nope, no clue.
Have a good day
The x-lock is double the price. It does a little more from what I've read but I just want to be able to shorten the line and the tool I've mentioned is made for only that. Can't be that hard rig up.
JenElio
JenElio
64,525
604,753
Loxahatchee, florida
Maybe I'm just too simple minded but.....why not just wrap around anchor point a few times or just use snatch block, recovery ring, etc?
Bighat
Bighat
875
3,737
Gallipolis Ohio
I thought it sound like a cool tool. Where you could need it, when you you really stuck and your only place to winch to is to close. Or, when you to far away and your winch extensoin rope is to long. I was looking at it for even winch some logs on the farm, up hill usually. They're heavy and you need to keep the winch line to on the last few drum loops, even some with a snatch block. This would be great, instead of having to move and setup again, just pull the winch line back out to the power loop on the drum and rig the line with this tool.
JenElio
JenElio
64,525
604,753
🤔....gotcha!...makes sense(ish) 👍
