Is this really a needed item when going to larger tires? Also does SATV have a forum discount? This wasn’t available to order during the last 2 sales but now is available for a pre order.
No it's not necessary, but not a bad idea. Send a PM to @SuperATV and he will give you the current discount code.Is this really a needed item when going to larger tires? Also does SATV have a forum discount? This wasn’t available to order during the last 2 sales but now is available for a pre order.
Just make sure the grease zerks work before installing!No it's not necessary, but not a bad idea. Send a PM to @SuperATV and he will give you the current discount code.
😆 Order placed
Will this work on a 2021? Web pag says 16-17. Is there a discount code? Starting to build for Moab and Colorado trip this summer.
Yup as I put it on my 21.Will this work on a 2021? Web pag says 16-17. Is there a discount code? Starting to build for moss and Colorado trip this summer.
Nope didn’t have to redrill, just make sure everything is loose and get all bolts started then slowly rotate tightening, no issue with mine.After 2017, a couple of the mounting holes on the frame got a little wonky. Seems to work fine in some...and not others. Can't remember exactly which bolt holes it was...but the were off just enough in most of those that it wasn't going to work without redrilling our mounting holes. We're supposed to have a complete update covering all of them soon, but I don't have a date yet. You could probably make it work just fine, but you may have to redrill the holes on the current model.
@tdhanses did you have to redrill yours?
I will say it was super close to needing to modify and had I tightened any of the bolts up then went to thread the others it wouldn’t work from what I remember but if all were loose then I could thread all and slowly it worked it’s way into place.Hell yeah! They must have had a few different frame runs/jigs, because its been hit and miss from what I've noticed. Popo did the same thing with the RZR 900 and the General. 2 different jigs from 2 different plants that were far enough off to require completely different arms for both....less than 1/4" off.
Thanks for the pic @tdhanses
And thanks for the update @DDDonkey . Good to know!
So is there a discount code for members of this site?Hell yeah! They must have had a few different frame runs/jigs, because its been hit and miss from what I've noticed. Popo did the same thing with the RZR 900 and the General. 2 different jigs from 2 different plants that were far enough off to require completely different arms for both....less than 1/4" off.
There is but you have to send him a PM to get it, they don’t post it for the world to Google.So is there a discount code for members of this site?
ThanksThere is but you have to send him a PM to get it, they don’t post it for the world to Google.
