P1000 Seatbelt delete kit?
rzback
7
22
Arkansas
Where can I get a delete kit for my 2022 Pioneer 1000-5 to do away with the limiter when the seatbelt is unhooked?
Reactions: toddvdh
bumperm
bumperm
1,851
6,656
Gardnerville, NV
Jumper wire and some electrical tape. Nearly free.
Did the same with a scrap of solid (not stranded, though that'd work) wire, then sealed the plug with butyl rubber caulking tape - if you don't have butyl rubber tape in your tool box of tricks, you don't know what you are missing. It sticks to itself and basically stays sticky. Very handy stuff.
bumperm
bumperm
1,851
6,656
Gardnerville, NV
I just buckle the middle seat belt into the drivers side. Not permanent this way.
But then you gotta fiddle around undoing one before you can plug in the other. I use my seat belt when things are dicey, or even out on the trails, but not around the house. Agree, it's half a dozen of one . . . etc. but I don't like nags.
Mark in Northern Iowa
465
2,082
Floyd County, Iowa
kramnella.wixsite.com
Read this thread, all parts are listed to make your own.
Speed limiter / Seat belt delete, remote controlled if you want
Have a good day
ODAMO
ODAMO
1,177
3,206
Good ol Monkey tape
Reactions: Rayger143
Rayger143
Rayger143
2,747
23,787
Winfield, BC Canada
9A06EC98 2A54 494D 83FE 827ABA0DBB87
Reactions: 05Willys
Scoop
Scoop
4,241
15,886
  3. Talon R LV
I'm probably the only one that kept the seat belt limiter even with a tune and 4 point harnesses. Sometimes I'll skip a helmet but I'm ok with the seat belt limiter.
From what I've read about how you ride, that's probably a wise choice! 🤣
There is certainly nothing permanent about a plug-in seat belt override bypass kit. :confused:
Reactions: 05Willys
