P500 Sedona Rip-saw tires
195,270
You've probably noticed the chainsaw strapped to the rear of mine in pictures when I'm on the trail. My buddy and I have opened miles of long forgotten overgrown trails in our NF. And it hasn't cost the taxpayer a dime, gratis, a favor to other riders that can now use them. As long as they aren't in P1K's, we didn't cut wide enough for that.
Piston is referring to the State Trails around here. Wouldn't want to be caught running a saw on those. They wouldn't take it as doing them a favor.
Private property or out in BFE...timberrrr!! ;)
Federal property we're on.
cornbread
East Tenn
Montecresto, I'm considering the Terrabite radial. Going to stay with factory rims. Looks like 27x9x12 on front and 27x11x12 are my only options.
Questions
Will this keep me between the fender wells? Need to fit in pick up bed
Will this make me tippy?
Read somewhere each Terrabite is 10 pounds heavier than stock, is this added weight a concern in power loss?
Reactions: Dp5hunter
AlR
AlR
470
1,166
Nanaimo, British Columbia
I
Questions
I have those sizes in an ITP mudlite on my P5. Fits between the wheel wells on the GMC 2500 no problem.
Questions
Yes you'll still fit the pickup bed, it will be tip pier and you will notice some powe loss.
Yes
Reactions: CumminsPusher
Well not exactly the answer I was hoping for. Reckon I'll need to do some serious figuring on which trade-offs I can live with. Thanks!
My apologies. Yes, you'll still fit between the wheel wells, Yes, the P5 will be more tippy than it already was, and yes you will notice some power loss. The added weight however below the COG is a positive. These have a truck style tread pattern and are designed for multi-surface. Good on gravel and hardtop. Not the most aggressive trail tire.
cornbread
East Tenn
My power loss concern is not in the way of top end speed. I creep every where. Have some fairly steep runs to climb where I hunt. One being gravel logging roads and the other a blazed atv trail on private property that can get a bit slick in mud, when it rains, but not deep. Thoughts?
You'll notice it more in the lower end gears. Where you use to pull in 2nd you'll be getting 1st, ect.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,808
183,554
Grand Junction, CO
Questions
If the Terrabite's are like the Rip Saws that I have they are much heavier which I do like because it does lower the center of gravity but I would not go with anything bigger than 25"s if you can help it. I know people that have will never go over 25" again because anything over that is really robbing power. That is what they are experiencing here in Colorado.
That sounds alright. Should I expect any rubbing when making sharp turns? Read where the 27 is actually 26 3/4 inches.
No, you should have no rubbing.
cornbread
East Tenn
Thanks for all the info. Called Rocky Mtn. for their opinion and was advised to go ITP Blackwater Evolution Radial 26x9x12 and 26x11x12. Anybody with knowledge of BW Evo's? Have a concern on blacktop.
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
those are great tires also but i belive they are heavier then the rips which are crazy heavy lol but cant go wrong with either on black top the rips are a bit wobbly for first few seconds until they heat up
Dp5hunter
Dp5hunter
3,056
Hazlehurst Mississippi
I'm looking at getting the Terrabites for my P500 for the PROTC. I don't expect we'll be doing much deep mud bot a lot of hard pack and black top road. And I will be getting 27s. :cool:;)
Are those DOT tires?
