P1000 Seizmik Doors?
ChadMarti
ChadMarti
7
14
Norwalk, Wisconsin
Has anyone installed the top-half doors from Seizmik on a 1000-5? If so do they appear to be solid? Do they seal up well? I see them on several sites for $475 with free shipping.
E
elkguide
3,377
7,963
Vermont
Sure do look good.
Hardwaterflyer
65
102
West Central Minnesota
I have Seizmik doors sitting in my garage not yet installed. I have the Honda glass windshield, hardroof, soft mid panel already installed. The windshield and roof look like they have to be removed to put the doors on. The instructions show the doors being installed with no windshield. FYI. All parts and materials look to be first class. But the Honda glass windshield definitely has to come off to get the door frame material on properly.
Reactions: ChadD and ChadMarti
Mind posting pics of the process and the completed project. Also, do you have side mirrors, and if so how they work with the new doors? Thx
V
Viz275
11
PNW
Had 8 degrees on the way to work today, I'm going to order a set tomorrow.
Did you get them yet? I have my eye on a set of these as well. I like that you can open the door from the outside without unzipping.
BrentK
11
Troy,NC
I like these upper doors, takes bout an hour and a half to put them on. Zippers are very nice. Good quality all around... they seal great much better than my friends Honda uppers.
Anyone have any good ideas to keep air flow from blowing around the shifter so much?
CEDAD1EE 1AD4 4840 9AF0 6EAFC06F49D8
TexasHeat
TexasHeat
30
25
Texas
i had installed the upper doors in november prior to thanksgiving 16 day mule deer hunting season. if you have a honda OEM tilt up windshield you will find it very difficult to install the doors so they seal properly. siezmek will send you a couple of pieces to add to your windshield that will either lower on one side or raise on the opposite side the bolt pattern for the bottom windshield attachment clamps. i can almost seal the door tight on drivers side but way off on passenger side. i tried every which way i could to tweak the door so it would seal but no matter what i did i could not completely seal them. they are very well made and extremely stout and i am sure if you purchased their windshield it would fit wonderfully. after i came up with a solution to seal all around the door it was fairly comfortable and as we all know if the machine is already warmed up it stays a decent temp inside and you wont freeze or get dusted out. i love the doors just wish there was another solution to the windshield clamps on their end so i dont have to change anything. But Heck, there is rarely a true plug and play aftermarket item out there anyways. i will give them a 6 out of 10 for fit on the honda 1000-5p LE. also a 9 out of 10 for the quality. one exception is the adjustment screw for the door hinge/swivel, it keeps popping out.
It was indeed very difficult, and it made install time much longer than advertised, but, in the end I did prevail, and I’m very pleased with the product, although, I did have to modify (read: improve upon) them to get a seal that was acceptable to me....
Reactions: Eltobgi
I had a long back and forth with the owner, who claims to have the OEM tilt up on their Pioneer 1000-5, and insists that the fit and seal is super!!! It may even be the one in their promotional video.
Yes and yes. With a couple mods they are a good fit and quality.
ofrcboy
ofrcboy
501
572
Oregon
I am going to buy upper doors for my 1000-5 before next winter, have OEM Honda top and tip up windshield. Are there only 2 options, Seizmik & Honda or are there other's? Looking for best fit and quality.
I’m really happy with my Seizmik and I have the same roof and windshield as you. CEC makes them that some members are using and really like as well.
Reactions: ChadD
MNHonda
0
MN
Brent, what kind of mid-panel, if any are running? I’m interested in these upper doors, I have the same windshield and roof as you but I want a mid panel to totally close in the cab.
Vikes79
Vikes79
SKOL!
10,889
105,646
South Dakota
  2. Talon X4 LV
most are running the Honda mid panel. If you have the hard roof from Honda you’ll need to close the gap between the roll bar and roof with foam. I use 2x2 square air conditioner foam doubled over to close the gaps in the roof.
Reactions: MNHonda
Buckslayr
141
353
Nd
I like my seizmik doors and mirrors. they trailer well and seal good on the front,still need to seal the rear a little better.
IMG 6457 IMG 6456
Reactions: 2018GMC
Hey I noticed you said the seismic doors trailered well I will be trailering from East Texas to Colorado to elk hunt about 1200 miles will they make the trip or would I have to take them off?
I’ve trailered mine from New Mexico to Montana and New Mexico to Arkansas. No issues.
