Shifter Removal
L
LBZDZL
California
Good morning fellow Talon owners! Has anyone here removed the factory shift lever and replaced with a dragon fire racing one? I am in the process of doing the shifter boot install as well as a hess shift plate and while I was at it decided I would like to replace the chunky shift knob. I am having a bit of an issue removing the old shift lever though and wanted to know if anyone has any experience with this? Do I need to disconnect from the shift cable and remove the whole unit, or is there a shortcut? Thanks in advance!
SLOWPOKE693
SLOWPOKE693
1,637
6,270
Somewhere in Texas
Grab the shift knob, twist it back and forth several times to break the glue bond and then pull like hell straight up. I did my shift plate swap without pulling anything out of my Talon.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
I think he means the whole shifter not the knob
  • Haha
Reactions: Montecresto
L
LBZDZL
California
I am talking about the shift lever, not just the knob. The knob is a relatively easy process.
PaulF
PaulF
1,462
4,810
Does this exploded view help at all?...
1627676300554
Reactions: Remington
L
LBZDZL
California
Thanks for the diagram Paul, I can see how it goes together pretty easily on the machine. I am looking for any real world experience from anyone who has actually removed one before. It looks like I may have to remove the whole assembly and then remove the spring in order to get the shift lever off. Just was wondering if there was a shortcut that people have used before I go through that.😁
JS45
JS45
24
58
Fla
You gotta pop the center console out then remove the shift gate. Then unscrew the pivot bolt/nut from the above diagram and remove it then pop the spring off and it comes right out. And I didn’t mess with removing the rubber knob. Just left it on the stock lever. I put the dragon fire lever on mine.
