P1000 Side panel install
vdefender
vdefender
17
49
Washington
These are the parts my dealer ordered to add the panels to my base model 1000-5. I only see the Clips listed there. Does that match what you're seeing, or is that the missing part you need?
Reactions: Lady01
L
Logey
9
Illinois
i was looking at the OEM parts diagram on Rocky Mountain ATV. it lists the body panels and screws to attach them but not the rubber grommets that the screws attach to. Part number 26 is the screw. Are your panels attached using the clips?
Body panel
Bodypanelscrew
Reactions: Lady01
56,680
@Plumber32 Plasti-Dipped his rig and it seems to be holding up pretty well. Far better than I ever thought it would. Maybe he's got some sort of magic Wisconsin plasti-dip or some secret plumber sauce....
66,211
Yeah, the hardener/clearcoat spray makes a world of difference
rustyneversleeps
rustyneversleeps
379
1,828
Montana
Is the hardener/clearcoat a separate can that you spray on top of the plastidip after its set? I was looking through your old posts, but couldn't find where you mentioned it before. Thanks
Reactions: Lady01
Seadonist
Seadonist
384
1,142
New Orleans
Ever get the rubber grommets issue figured out? I just ordered a new set of panels for my 1000-5 but it only gave me the option to purchase the screws for installation. Didn’t see any grommets on the parts diagram
Reactions: Lady01
L
Logey
9
Illinois
they are standard 6mm rubber wellnuts. i ordered some from Amazon but haven't installed them yet. My panels are on backorder. As soon as they come in I'll let you know how they worked.
Reactions: Lady01
Seadonist
Seadonist
384
1,142
New Orleans
These are the ones that I picked up from Amazon. Product info didn’t say what thread pitch these are. I hope it’s the right pitch.
Be6b91b519426eb439283e05c0ea8790
Reactions: Lady01
L
Logey
9
Illinois
Those are the same that I ordered. They are the correct thread pitch. I measured with a caliper and think a 15/32 drill bit would be the best choice. A little tight but it would keep them from spinning when you screw the bolt in.
Reactions: Lady01
Seadonist
Seadonist
384
1,142
New Orleans
Thanks Logey
Reactions: Lady01
vdefender
vdefender
17
49
Washington
I'm still waiting on the back ordered front door panel though :(
Reactions: Lady01
L
Logey
9
Illinois
Looks great.
I have the front door panels, just waiting on the back doors and bed! supposed to be here in a couple weeks.
Reactions: Lady01
Seadonist
Seadonist
384
1,142
New Orleans
15/32” bit is definitely the way to go. Used a little soapy water to lube up the well nuts and used a small flat head driver to wedge them in and then turned and pressed them in until they snugged down flat. It’s a tight fit but it keeps the nuts from spinning when you bolt on the panels.
E3c98eb016f16a3d02c08e00f5b18e37
5be427335aa65e4cb64a363e04df17ac
Efded633ab2ba0711cc72d38112fc2d5
04e637d8bc92fca6d8370db2c96cc701
6715b1cb7309558ee0cd564ce4c9e450
Reactions: Lady01 and Isaiah
Seadonist
Seadonist
384
1,142
New Orleans
vdefender
vdefender
17
49
Washington
Shiny! What was your reasoning for going with the nut and screw hardware rather than the push pins?
Reactions: Lady01
