P1000 Simple reverse light?
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Mine is more so for reliability. A plug in sealed connection is always better in my mind than a wire splice.
Normally i might agree with that but only electrical problem I've had is the sealed tps sensor connector lol.
Reactions: ToddACimer
Amre2me2
Amre2me2
381
1,423
Colorado
I use my Honda for 80% business/utility and maybe 20% for fun. So I could care less about drilling a hole or splicing into a harness. I've got mine just about setup with everything I need and it's working out very well.
Reactions: elkguide and Delton
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
That would be cool to use one for work. Mine takes me to work does that count? Lol. It's 100% all fun. I think I'm pretty much done as well. Maybe a set of sliders and chromoly cage over the winter.
rubicon05
rubicon05
234
310
Southern, IN
Correct, it's just a harness that plugs into the Honda reverse signal wire above the back side of the engine
those that used this harness - it has 3 wires coming out of it, one with an orange harness and than 2 other wires, did you leave just those off or cut them off altogether? The last time I did this I just cut the harness of and hardwired, but I purchased the harness this time as it was only $5.95.
ToddACimer
ToddACimer
Pioneer 1005-2
3,739
15,802
Oshkosh, Wi
I clipped the terminals off the 2 wire pair and put on a 2 pin Deutsch connector which connects to my lights. You only need the green and white and gray and white wires for power and ground
Reactions: ohanacreek
OnTheJob
OnTheJob
426
925
Bristol, NY
I sealed the ends I didn't use with heat shrink and taped them up with electrical tape. Then made the same connections above. Really easy.
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,606
Ridgeway, SC
That harness did not fit on my 2016 P1K-5. The connectors were significantly different. I tapped into the reverse ground to activate my lights
Reactions: Sxsjerry
OnTheJob
OnTheJob
426
925
Bristol, NY
Worked like a charm on my 2016 P1K-3
Sxsjerry
Sxsjerry
5
Somerset Kentucky
You were correct, it will not fit 17 p1k-5
Already ordered by the time you posted, o well try again thanks
G
gpd2111
20
22
US
I took out the dummy plug that is where the back up alarm plugs in. Then went to my dealer and picked up two female terminals. Connected my wires to the new terminals and plugged it in.
Reactions: Tramguage1
elkaholic
elkaholic
2,097
8,606
Ridgeway, SC
To be clear, there are two harnesses available. One is the auxiliary power harness that distributes power from a red plug under the seat of a P1K and the other is for a backup alarm and goes in-line between the two halv s of the existing harness for gear position. It is this latter harness that would not fit my P1K. The connection is an 8 pin connection and at some point the connector was changed so the backup alarm harness was useless other than to donate wiring.
I used the auxiliary power harness, a piece of the backup alarm harness and some additional wiring. I pulled power from the auxiliary power harness and tapped into the ground signal that tells the pcm that the rig is in reverse (the same wire that the backup alarm harness should have done more cleanly)
STRATOSMICRO
STRATOSMICRO
37
22
49221
  2. Other Brand
Try this harness and you do not need to spice anything, it plugs directly into the factory Backup Alarm connector.
HONDA PIONEER 1000 3P/5P, ACC OR BACKUP LIGHT WIRING HARNESS, 6 FT, PLUG & PLAY | eBay
P1000 bu
Johnny_C
Johnny_C
303
143
Western N. Carolina
I installed a winch, aux battery, light bars,
cube lights, dome lights, blower fan, etc,
and the only interface to the factory wiring is
the power wire between the two batteries,
because I didn't want to modify the factory
wiring in any way.
So my response to your question is that I
installed a cube under the bed, and I control
it manually with a switch on the dash.
Reactions: Sxsjerry
BlueBadger05
BlueBadger05
39
41
If I am using 08Z02-HL3-A001 for the reverse lights and I just want to wire 2 small lights direct, what wires am I connecting them to?
There are 2 wires for the factory Honda horn (green / white with black stripe)
There is a single wire for the back up alarm (white with black stripe)
There is a large black connector for a factory vehicle accessory socket (green / white with black stripe)
I want to wire it to the small "rock lights" that many have installed.
Thanks!
ToddACimer
ToddACimer
Pioneer 1005-2
3,739
15,802
Oshkosh, Wi
Thanks!
The green/gray and white black will work for reverse lights. If you're looking to run the rock lights off a switch you'll need to add another switched ground and then the white/black will provide power for your lights.
Reactions: BlueBadger05
BlueBadger05
BlueBadger05
39
41
Thanks ToddACimer!! I don't plan to use a switch for these, I am going to install a 12" larger LED light to the rear that will be switched.
For future reference if anyone has this question it is the "Honda Horn" wires. (green / white with black stripe)
If your new lights have just a red and black wire coming from them. Hook the red wire to the white with black stripe wire. Then hook your black wire to the green.
Reactions: MMW and TimG
