SMV triangle and mount on a 1000-5
Chelsea_Boy
Chelsea_Boy
Paw Paw Michigan
What’s your thoughts on the safety triangle and where you put it. Could it swing out when needed ? I’m in SW MI so will be having it on show when I go out on my side roads. As far as I’m aware I can be legal …ish on my under 35mph roads this way … any help would be appreciated
TxDoc
TxDoc
2,153
7,226
TEXAS 🇨🇱
photos.app.goo.gl
I don't know if this is any help. But, I used a Honda clamp that lets easily sneak it in or off.
This is a side photo. If you need a different angle, let me know.
Good luck on your project
7c5f3c05da2db39650cc0ad45e04a38f
Sent from my motorola edge plus 2023 using Tapatalk
Robobrainiac
Robobrainiac
2,550
8,957
I am in MO and I am required to to have a SMV Triangle. I also use a flag.
Reactions: Remington and TxDoc
115,286
You are legal to drive on any non “M” roads or interstates in michigan on the shoulder at a respectable speed in our state. That said, this is only legal by a county to county basses.
So contact your county’s sheriff dept to find out your co’s rules.
906UP
906UP
14,233
134,862
da Yoop
You are legal to drive on anything other than “M” roads or interstates in michigan on the shoulder at 25mph or less in our state. That said, this is only legal on a county to county (sometimes twp to twp) basis. Each county/twp can adopt an ORV ordinance but it must follow state guidelines.....ie. 25 mph max is statewide when on a public road.
Updated & corrected a couple things for yah @Remington
Scoop
Scoop
5,130
20,277
  3. Talon R LV
You cannot drive on the interstate highways, @Remington. Those are federal roadways (e.g., I-75). Further, not ALL state highways are open to ORV use. The MDNR and local governments get to decide. Beyond that, there are equipment and/or PPE requirements depending upon the ORV, operator, and passengers, time restrictions, speed restrictions, location (relative to roadway) restrictions, etc.. Far too many for me to keep track of, that's for sure. Just to be clear, you can't just strap on a triangle and go wherever and whenever you want. Otherwise, there would be absolutely no benefit to making an ORV 'street legal'.
P1K5Dave
P1K5Dave
2,244
8,419
Petoskey, MI
He meant to type "non" rather than "on."
You are legal to drive on any non “M” roads or interstates...
Again, this is a state law provision that allows individual counties and municipalities to set the rule to their liking. Here in Northern MI, pretty much all of the counties are open to ORV use on the shoulder for county roads. There are exceptions in and around towns.
Also, I don't think the slow triangle thing applies at all in MI.
115,286
And @906UP
I should have took the time to re read what I wrote. What u said is exctly what i meant. Thanks @P1K5Dave for seeing that.
Ill correct it. My bad.
I use my phone most of the time and im in my service truck usually waiting on dispatch and I get interrupted.
I dont know why, but for some reason I type and hit the space bar, it will take something out and I know i typed it. It happens when I text to dispatch all the time too🤬
I fucing hate it.
Yeah im not that stupid, I iknow u cant drive on a state highway duh…🙄
you'll probably die if you do.
906UP
906UP
14,233
134,862
da Yoop
And @906UP
I fucing hate it.
Kinda figured that was the case.....happens to me all the time, old mechanic thumbs I guess
Scoop
Scoop
5,130
20,277
  3. Talon R LV
Happens to me, too. I just didn't want ole @Chelsea_Boy getting pulled over after we told him it was cool. :oops:
115,286
Agreed😉
Reactions: TxDoc
