P500 snorkel for p500
Dp5hunter
Dp5hunter
3,056
Hazlehurst Mississippi
I see that there is a factory snorkel for the P1K is there one also for the P500.?I would really like to put one on my P5 but don't want to void my wurenty.
JCart
JCart
897
2,024
Kamloops, BC Canada.
Pix of what I did to mine and you can always put it back to stock, mind you I'm not intentionally heading into the deep with it. Pix are in my sig link. So far I'd say it's worked awesome and has reduced filter change out significantly.
j
Dp5hunter
Dp5hunter
3,056
j
Wow, that is the fastest reply yet and thanks I will be checking it out.
JCart
JCart
897
2,024
You are welcome, easy to assemble I used black plastic pipe and just glued it together with the specific yellow glue you get from hardware store. You'll see I added a larger diameter section of pipe to soften the harsh intake note (sorta shade tree tuning). Pipe was 2" and 3" diameter standard plastic drain pipe.
j
Dp5hunter
Dp5hunter
3,056
j
How do I find your mod to vew it?
HUCK
HUCK
1,047
2,315
ARIZONA
Increasing the cleanliness of your air intake system will not void your warranty . A friend of mine went to hardware store with his p5 and bought black plastic pipe and elbows . Attached to his stock air intake then ran it up under the top of his roof and put a uni filter up there with a otter sock on it . Now he needs to change the stock filter every 1000 miles maybe .
Reactions: trigger
Dp5hunter
Dp5hunter
3,056
I will check with the local Honda dealer and If that's the case I'll do the same.
JCart
JCart
897
2,024
Click on link in signature, will take you to my Dropbox account and you will see folders Click on the P5 Intake and also P5 Cab folder to show how the intake integrates with my cab.
j
Dp5hunter
Dp5hunter
3,056
j
Thanks JCart will do
Talen
Talen
160
189
Central PA
Click the swamped link.
I had to use a reduced end andvfile it on a bevel to fit in rubber sleeve on air box. But it fits right in and clamps down. I still need to run new vent lines for diffs , fuel tank and radiator
162,465
You have to take the rack off to do it that way right? Why not just do it up near the roll bar?
I'm just asking what was gained by going back that far?
Talen
Talen
160
189
Central PA
No. I used two rubber couplers so i could install in several pieces. I guess it seemed just as complicated to make it fit onto stock snorkel. And i didnt want to cut it. Though i did cut black fender towaeds cab. But you cant see it. The negative to replacing stock intake is noise. It doesnt bother me. But you can definitely hear it haha
Talen
Talen
160
189
Central PA
I dont think i would trust that thin cheap intake to keepnout water either
