P500 Snorkel question!
mwsmith818
7
21
I’m working on re-doing my p500’s snorkel (was leaking somewhere) and I was wondering if you guys thought it would be a good idea to silicone around where the intake boot on the bottom side of the air box goes around the throttle body?? I did last night and I’m kind of thinking twice on it.. if they make a good seal without the rtv I may rip it off. Thanks!
NTCPrezJB
NTCPrezJB
Retiring Member
113,000
976,641
Hidden
I wouldn't bother to undo it at this point.
WillyBill
WillyBill
Wheeling Addict
478
1,904
Clinton, Utah
  1. Talon X LV
Anything in air system that gets caulk you should use urethane like Sikaflex. Rtv not good for flexi stuff in the long run. Yes, seal air box hoses inside snd out IMHO.
WB
Reactions: NTCPrezJB
mwsmith818
7
21
I’m really not wanting too, but I overthink too much and cent help but think about a piece of that silicone somehow breaking off and getting sucked into the throttle body or head🙄😂 likely or no?
Reactions: lee
lee
lee
Village Idiot
2,403
13,608
Springfield Ohio
The air filter/throttle body/intake tube structure is the same for bikes/dirt bikes from the dawn of time. It’s one of those “if it’s not broke don’t fix it” kind of things. Not sure how bad a glob of sealer would be in the engine but if you ever have to open the system make sure it is cleaned off so you don’t get a air leak and let in half the dust in the world.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Not sure what size pipe your running but hondas biggest weakness is almost always the the lid. Smaller pipe puts more suction on box. Aka lid flexes breaks seal. I had a small leak on my 700 and i couldnt find it so i put my go pro in the airbox with a light and found out it was the lid. Not sure if you have the means of doing something like that. But i recommend anyone running a snorkel. Really gives you a peice of mind
Reactions: Bastardchild
Bastardchild
Bastardchild
1,978
7,251
Orange Heights, fl
I pull the rubber ring out of my airbox lid, run a bead of silicon in the groove that the rubber seal came out of, push the rubber seal back in the groove, then silicon over top of the rubber ring. Install the lid and let it sit for awhile before starting. The next time you go to change your air filter the lid takes some serious prying to get it off. Also, its a little time consuming peeling the dried rubbery silicon off of the rubber oring, but I think its worth it to have peace of mind when in deep water. Also, the other rubber pieces that push into the airbox I remove, put silicon around them, then reinstall into airbox. I know people that dont though and have no problem. Just my 2 cents.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
I made some proto putty. As a thicker seal. Basically homemade gasket reuseable
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Actually trying to look into something different for my dads airbox. The big red lid is super flimsy. Going to try and brace it on the inside with a plastic welder.
