Theres a couple threads on here already about them. Very easy to do your own . Cost me about $25 to do mine . And theres no need to cut holes in your front plastics.
how did you do it without cutting the front plastics? Through the cup holder?
Yes I came up through the passenger side cup holder. View attachment 9655 View attachment 9656 View attachment 9657
I used different 2in pvc fittings from homedepot (cant tell you exactly which ones right now without taking it off ) I came off the the factory front box and went behind the glove box and up threw the the cup holder. I takes aliitle time to get the right fittings to snake it behind there but can be done fairly easy.Can you explain materials used please and how you got to the cupholder.
did you have to seal off factory airfilter box?
Ya it would be better but the only thing i could fine stuck up to far and interfered with the hood. I actually stuck 2 in pipe threw the hole and attached the rubber factory piece to the 2in pipe. It looks like I just put the 90 right on the top but theres a 2in pipe attached to that . Not sure on the second question .Thats 2 inch tubing? That looks big. Just a question here. Wouldnt it be better at the box to use a rubber coupler and go on the outside of the tube coming up instead of the inside. No way for water to seap in.
Also do they make a top piece like joeymt33 is using on his to fit the pvc?
I know better than to take away my wife's cup holder. I get away with alot but that would be crossing the line.I saw that. That's a good idea too. Everyone has their own tastes. For me, I didn't want the intake noise in the cab nor did I want to loose the cup holder.
Are you guys concerned about fouling the main air filter? It doesn't look like any of the the snorkels projects include a pre filter.
I have been talking with them for a week. They just informed me today that it won't work with the 2 pc honda windshield.Just wanted to post the snorkel i found for sale as a package deal
If anyone knows of any other or better ones please post them here. Trying to find a snorkel. When is highlifter gonna release theres?
