P1000 Snorkling the Pioneer 1000!
You going to snorkle your p1000
  • yes
    Votes: 59 78.7%
  • no
    Votes: 16 21.3%
  • Total voters
    75
Scooterchris
No longer active.
Dec 25, 2015
396
237
you're a better man than me... I'd be calling every day... for real.
Just giving them time. I'll Prolly call tomorrow to see what's up. It's killing me I've got so many things in the works but can't do nothing cause its broke down.
New rims
New tires
New white body panels
New custom aluminum switch plate
Led interior lights..
All just waiting
Scooterchris
No longer active.
Dec 25, 2015
396
237
Still got the front white fender on back order just a fyi don't order the white ones
Tot
Tot
661
462
Des Arc, Arkansas
I'm still going with the white. I'm a patient man lol.
The one I was supposed to get (a white 3 seater) got pushed back to the 14th, so the guy I was working with at my dealer found on for me at another dealer so I got my white one yesterday
Reactions: Scooterchris
Scooterchris
No longer active.
Dec 25, 2015
396
237
might have to go a different route... i have the two piece windshield and the clamp is gonna be in the way
You dont. You just need to raise the pvc straight piece coming out of the cup holder just enough them put the 22 degree elbow on just at the right spot so the windshield will fit. I'm gonna get a windshield sooner or later and when I redo mine I'm gonna have to take more time to make sure it fits.
It's gonna take a little more time and measurement but it should work
Reactions: mikegzales
Scooterchris
No longer active.
Dec 25, 2015
396
237
wont be able to get bellows before this weekend... what size is the hose
Shoot idk. The diff are tiny little hose. The sub trans and fuel tank are 1/4 inch I believe.
Looks good. Let's see what you did in the hood area
Scooterchris
No longer active.
Dec 25, 2015
396
237
same as u under the hood just a bigger hole because of corona
Hahaha I'm glad I'm not the only one. I was sipping on some bud light. By that time I could barely work the dremel. That's why my buddy ended up building it
CharlieLong1
Slidell L.A
Can you plz give me some info on how you made this connection. Tried to find a rubber boot to fit but could not find one. The one under the hood that is. I am reading put a 2 inch rubber boot inside the stock snorkel pipe riser under hood.
Dasmoeturhead
This only cost me a couple of hose clamps,zip ties,and a hose I had laying around.
20160617 161129
20160617 161148
20160619 122702
Reactions: Bradmc87
