Soooooo any ideas why my airbox filled with oil?
66,868
Check valve on top of the head.
But I don't see any procedure for checking its operations in the service manual.
Reactions: Smitty335 and ChadD
5,425
24,913
There's a crankcase breather hose (#6) venting into the airbox, shown in the service manual Page 7-16. It's hidden from sight, above the throttle bodies and it looks like the airbox has to be loose before you can get to it..
5,425
24,913
The filter element itself or the composite around it? Not sure if you've seen it, there have been some R2C failures but it's the composite, not the element itself. Highpocket has a thread going on it.
Sheetmetalfab
Sheetmetalfab
2,172
13,598
Alaska
Reactions: ChadD
Sheetmetalfab
Sheetmetalfab
2,172
13,598
Alaska
8CAD1FB7 9F89 4820 83D4 EB7A632D1785
bumperm
bumperm
1,899
6,778
Gardnerville, NV
Oh _rap! Guessing lots of abrasive taking out the rings, pressurizing crankcase and blowing oil out the breather hose??
Bad news! Sorry.
And I'd been thinking about getting an R2C after reviewing specs. Glad I waited.
Sheetmetalfab
Sheetmetalfab
2,172
13,598
Alaska
Bad news! Sorry.
Yep that’s my assumption.
will do a leak down test to confirm.
sandbaja
sandbaja
130
421
San Diego, CA
  1. Talon R LV
  2. Talon X4 LV
The amount of force (suction) to tear and pull in the membrane must have been considerable. I'm wondering if filter membrane blockage increased to the point that overcame the strength of the membrane. What does the other side of the filter look like? How many miles on the filter?
Screenshot 2021 08 22 074213
Sheetmetalfab
Sheetmetalfab
2,172
13,598
Alaska
400 miles on filter.
sandbaja
sandbaja
130
421
San Diego, CA
  1. Talon R LV
  2. Talon X4 LV
That's not many. Certainly not enough to block the membrane. I just installed V2 of the R2C filter and will check routinely plus I will be installing a prefilter. It sounds like you had no indicators before it went catastrophic. I hope this turns out the least amount of painful for you.
bumperm
bumperm
1,899
6,778
Gardnerville, NV
We are talking about the new R2C filter that has failed early on after initial distribution, right? The cause of those failures being due to the potting, or sealant material that bonds the filter media edges to the frame breaking down or coming loose.
Oops, sorry. I was thinking you were dealing with the new R2C for the Pioneer, and you are dealing with the Talon version. Disregard my post.
sandbaja
sandbaja
130
421
San Diego, CA
  1. Talon R LV
  2. Talon X4 LV
Yes, I'm calling them V1 or built before 8/11/2021. V2 built after that date. The only way to tell is if you receive a new gasket and the shipping date on the invoice since there is no stamp on the V2 filter.
SLOWPOKE693
SLOWPOKE693
1,849
7,329
Somewhere in Texas
