Spacer suggestion needed.
bigr244
bigr244
136
194
US
I'm running 26x9 all the way around on 5+2 ITP steel.
I'm not too concerned about staying at 50 so what do you reccomend for spacer width?
I'm currently wider in front than rear.
First thought was 1" on rear but now I'm having second thoughts.
Rick
Sent from my SM-G935V using Tapatalk
43,293
Rick
I think you should go as wide as reasonable. I am OEM rear wheels front and rear, and I'm planning on 2" rear, 1.5 front combo.
I think your wheels already give a bit more offset, so maybe 1/1.5 F/R for you? Kinda a personal preference thing I guess...
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
I do plan to add 1" spacers to the back end. Just haven't done it yet. Read somewhere that with our setup that evens out the front/rear track width. I don't personally plan to add any spacing to the front because I understand that it increases bump steer. Someone correct me if I'm wrong.
182,404
It probably would add some bump without ESP. After I put the 5+2's on mine it felt stable, just needed rear spacers for even track width. Then I went and added more weight up high and it felt like it needed more.
Reactions: SouthwestORV
RB3offroad
RB3offroad
1,714
4,826
Tempe, AZ
We are in Arizona as well and we run 1" all around and it made a huge difference and does not feel tippy at all. I would never ride without them now
bigr244
bigr244
136
194
US
But wont that still keep the fronts farther out than rears?
bigr244
bigr244
136
194
US
If I want it to track equally what's the best option?
RB3offroad
RB3offroad
1,714
4,826
Tempe, AZ
If you are looking for equal you can do it 2 ways - 1" back or 1" in front and 2" in back. Hope that helps. I run OEM and I put 1" all around and like I said I would not change it. You can also call me if you would like. 480-389-7486
RB3offroad
RB3offroad
1,714
4,826
Tempe, AZ
Remember RB3 also has 10 off for orders over 120.00 use code taketen
bigr244
bigr244
136
194
US
Man you are missing out with OEM. LOL I was waiting and waiting and now I'm regretting and regretting. I'll give you a buzz
bigr244
bigr244
136
194
US
Is that what it is? Well its driving me nuts. I'll measure when I get home.
NitroxDiver
NitroxDiver
488
918
Concord NC
Stock wheels on my machine. I started with 1” on the back to even it out. This helped a lot with stability. Later I found a good deal on 2” spacers so I put them on the back and moved the 1” to the front.
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
Did you add EPS to yours?
500oneer
500oneer
15,000 mile club
424
1,080
Central PA
Rick
I have 5+2 wheels with 4 26x9 tires and no spacers. It’s great when I’m in tight areas and I don’t have to worry too much about clipping the back wheel and frame.
