Spacer suggestion needed.
Chuckie3
216
408
New Fairfield ct
If you had 5+2wheels with 26x9 front and 26x11 rear no spacers would the track be the same?
195,226
It would be real close. I don't think any wheel, spacer or tire set up makes it perfect. Measurements change day to day it seems, psi, load on machine, direction the wind is blowing...;)
Reactions: SouthParkColorado
Splorin
320
904
Maine
I had a 700 Rhino in the 'sued by everyone' days and Yamaha's agreement was to add 2" spacers to the rear and delete the sway bar. Dealer was not supposed to give you back your sway bar but mine knew me and my machine and I never put it back on anyway. I ran stock aluminum rims (6" fr-7.5"rr same as Honda) with 25x10x12 Baja Cross's and Progressive shocks. When dialed in shocks helped but the 2" in the rear with no bar was huge difference in stability. Narrower front rims kept bead out of trouble. I had a set of 1" spacers laying around and put them on the front with not much noticeable difference except I ate more flying filth! This was a 60 plus mph machine. Don't know 'percentage' of benefit but rear spacers probably do most of the work. I'm going to put 2" on the back with 28x10x12 Blackwater radials this summer on the P5 I just picked up and see how that works.
