P500 Steering or shocks
bobbybog
103
192
WV
So I am looking to spend about 5 to 600 on a new mod. I was thinking power steering but should I consider front walker evans shocks instead?
What would you buy if you could only Choose one?
Backwoods
Backwoods
32,349
331,981
Douglasville ga
Shocks, you can do p/s later they steer pretty easy anyway.
Reactions: Chooglin
HUCK
HUCK
1,047
2,315
ARIZONA
Save your money . They steer easy and after you get a few thousand miles on it the ride is very good .
OK , If your pounding it and bottoming out your shocks then do the shocks but if your shocking for a smoother ride . Save your money .
bobbybog
103
192
WV
Well I got about 1500 miles on it and the ride still sucks. I get bounced all over the WV trails here.
Reactions: 500oneer
HUCK
HUCK
1,047
2,315
ARIZONA
From friends who have W E shocks (once they tell the truth because they spent so much on them) the ones who got them for a smoother ride were disappointed and the ones who were hammering their rides (RZR guys mostly) say they are much better .
When I got just over 2k on my pioneer and got my air pressure down to 7lbs mine seems to ride really nice .
My RZR has power steering and it is nice but I can't convince myself it's worthwhile on the Pioneer .
Maybe if you have a plow I would think it would be a necessity . Ok , that's my 25 cents worth . lol
Backwoods
Backwoods
32,349
331,981
Douglasville ga
And it will continue to suck I used to have a 500. 5.9 inches of travel ain't much to work with. But they are amazing machines and will do whatever you ask of it.
Russ989
Russ989
22,569
146,535
You need the shocks for sure, the 500’s steer pretty good.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
I ask this friendly, what are you really wanting to do? That is, do you just want to spend 5-600 on the P500 for an upgrade/accessory or are you trying to solve a specific issue with the machine?
11,321
84,118
Fast and bumpy, maybe shocks. Slow and tight trails, maybe power steering. But a good third choice if you don’t have it is the front locker through the rough stuff. Like a lot of us here, its just what order you decide to add over time. LOL. Good luck. EZ Power Steering and Locker installed.
snakeriver
272
596
Clarkston Wa
For what it is worth I have had power steering since day one and would not change my selection, plan on doing the locker for my next purchase, and shocks will be my third selection.
Reactions: Mudder
bobbybog
103
192
WV
Thanks for all the input so far. I think I am trying to solve multiple problems actually. I typically ride pretty quick. I ride with a big group of rzrs on WV trails. I don’t have much problem keeping up, but definitely hit some whoops from time to time that bottom out the suspension for sure. Some of them teeth jarring.
I have also come across some high speed rocks I have hit that nearly ripped the steering wheel out of my hands and I assume the power steering will help with that.
As for the locker? It is farther down on my list. I rarely really even need 4 wheel drive and I have never been stuck in the P5.
Reactions: Eltobgi
It will definitely help with that problem.
Backwoods
Backwoods
32,349
331,981
Douglasville ga
Mine was ok riding it wasent designed for high-speed performance . Taller tires with more sidewall cushion helped also. Not getting in a big hurry did wonders for it's ride, but it was still brutal at times but knowing it has small travel numbers and riding according plus I had a 17 with " better shocks" may have contributed also.
bobbybog
103
192
WV
Is the 17 shocks really better? If so maybe that could be a lower cost answer. I am afraid I will get the walkers and not think it is that much better.
nctrailboss
nctrailboss
440
1,454
north carolina
I thought they recalled the 15 and 16's for a shock change.You can't get the part #'s for those years but you can get the 17 and 18 shocks.
bobbybog
103
192
WV
It was my understanding that the Canadian folks got a shock change and U.S.A. folks got a sticker. Someone please correct me if I am wrong.
