P1000 Steering wheel
aauman88
aauman88
1,091
2,846
Thinking one of these
91AFB4CF 1BD7 459E 9A65 F9882B12FC59
Ya I like the finished look, resembles factory. The boot comes cheapest with hub assembly then throw that one away. You can do a release but it’ll sit back a little further.
aauman88
aauman88
1,091
2,846
So the boot will have a way to attach to whatever I use?
It should slide over the correct adapter. I had different setups including a quick release (which I didn’t use because lost some distance and it would’ve worked on all I had.
aauman88
aauman88
1,091
2,846
Awesome thanks. @TerryH hows the distance to paddle shifters? About same as stock?
aauman88
aauman88
1,091
2,846
This one work just for the boot?
Think can find it cheaper, you’re just looking for the boot so doesn’t matter but I think that would do. Looks longer but needs trimmed so no biggie
This is more what I used.
38BE77B4 8F9C 4719 8F5E EBF6220D7D68
Well that’s the thing about a sport coming into market, the aftermarket world builds stuff. Much easier then having to figure it out
62,425
I'm trying to find one I like and keep running across this problem....
1591723095369
aauman88
aauman88
1,091
2,846
I wound up ordering this one to start with. Found a $180 MoMo that I love but started out cheaper. Guess hard part is getting adapters setup and then after I can easily change to any wheel. Think I’ve got $75 in everything ordered including quick release
86181653 4C8B 4F8F 8C81 3B8944B620C8
  • Love
Reactions: CumminsPusher
MFG
MFG
191
293
East Texas
Just incase someone does not know, the Talon and the Pioneer are the same steering wheel.
Reactions: TripleB
62,425
Nice, I like that one. Did you check the description to make sure it's not actually a 320mm?
aauman88
aauman88
1,091
2,846
It says 350mm in title and in description so I hope it is
Reactions: Adam490
62,425
Which quick release did you go with? I was going to get the fixed Hess until I got to shipping and it was $24....
62,425
