P500 Still too loud!
Spellmajr
Spellmajr
375
1,143
North MS
And following the Hondasxs.com rule (it didn't happen without images) my box of earplugs arrived at the door just now.
Al
I second that. I started wearing them recently. I work around aircraft all day so I'm used to loud noises but we also are required to wear hearing protection. So I got foamies like that to wear when I go on long rides, Or ride it on the street. Heck I even started wearing them cutting the grass.
RumpRocket
189
295
USA
View attachment 49463 I can attest that rubber works better for noise and heat than the foiled carpet mat. This is EPDM rubber roofing material. Thin and conforms easier.
Are you still using the EPDM Rubber Roofing material as a sound and heat barrier?
196,849
Yes and I like it better than the carpet mat I had in there. First time I power washed it I noticed that I had a couple of little puddles under the seats, where the rubber drooped down. I cut a couple of small holes so they would drain out and it hasn't been a problem since. I never have to take it out other than for maintenance or mods.
Reactions: RumpRocket
RumpRocket
189
295
USA
Is this similar to what you are using.....if you can recall? https://www.amazon.com/dp/B074W9L6GL/_encoding=UTF8?tag=sxsweb24-20
196,849
That's it. I build commercial buildings and got it from my roofer. Lays pretty flat, easily cleaned and durable as hell. Here it is installed.
Rubber
Reactions: jinx and RumpRocket
KYhillbilly
KYhillbilly
562
1,713
Ashland, KY
I used the foam flooring pads you can buy at Harbor Freight, Tractor supply, or rural King. $15.00 for a 4x8 roll, also used in the bottom of my aluminum golf cart bed.
However if riding fast or for any length of time i used ear plugs or my bose noise cancelling ear buds so i can listen to music without going deaf.
Russ989
Russ989
22,645
147,291
I never really noticed, I just get on and go....that is the point I thought. Lol
Reactions: joeymt33
Russ989
Russ989
22,645
147,291
You've never experienced the seat heat yet? You must've heard that rear end rattle chains?
I’ve experienced the seat heat but my rear end is fairly quiet. You can hear a little when she’s going about 35, not bad though.
196,849
Riding on a hot day and going through some water will have you feeling the burn, it's an issue on all these Pioneers. Easily dealt with though. The noise from the engine, rear end and exhaust heat shields isn't unbearably loud but installing a barrier does make a difference. Don't know if you're going to the takeover, I'd give you my old one.
Russ989
Russ989
22,645
147,291
Thanks for the offer @trigger, I wish I was going to the takeover but not this year. Going on a hog hunt in Oklahoma in March and have other commitments that will keep me from going this year. I might ask my wife’s cousin if he can get me some material to make a heat shield for the p5, he works in the engineering department at Hendrick Motorsports.
Reactions: Gassygordo
Russ989
Russ989
22,645
147,291
I think that's self sticking isn't it?
Yes it is, my thinking was to cover the under side of the seat to prevent a good portion of the heat. Some guys are covering all the way to the air box which blocks even more heat, this wouldn’t work as well for that.
Twangin
Twangin
131
276
NC
So just to sort of follow up here.. I’ve only had my P500 for a week.. I definitely see now what everyone’s been saying about it being a bit of a noisy machine. Not bad in my opinion, but noticeable. Specifically, what stands out the most to me are
1) sorta clanky when shifting in AT mode at really slow speeds
2) a “whining” sound (from the rear diff?)
3) lastly, I feel/hear almost like a tiny bit of play in the differential/driveshaft when creeping around 5mph and hit bumps that cause a pulsing of the throttle with your foot.
Are these all normal things I’m experiencing with a 1 week old machine? Again these are all very minor in my opinion as this is an off-road machine, not a cushy road cruiser.
@trigger I’m very interested in getting the rubber roofing mat and installing if you say it helps
RumpRocket
189
295
USA
I used E-Bay instead of Amazon.....the one listed on Amazon had a conflicting description in relation to the thickness.....Although I believe this is the same company ...anyway shortly after ordering on E-Bay it was sent Fed-X......much faster shipping than Amazon....I ordered a 4 by 10 piece .....figuring I can double fold in the back...... 10' RecPro EPDM Extreme Duty RV Rubber Roofing - By The Foot | eBay
