P1000 Stinger rely issue.
nitrotmann
nitrotmann
52
150
  1. 1000 6 Crew
Haven't found the correct search terms apparently... So here goes.
The singer is bleeding almost 10v to my Fuse box.
I've tried tappy tap tap on the side of the stinger, but still bleeds the nearly 10v.
Now I know I should have gotten the Cole Hersee.
Am I missing something? It's wired per Robert Sparre's excellent video.
Thanks
Sent from my SM-S908U using Tapatalk
Reactions: TxDoc
bumperm
bumperm
1,849
6,649
Gardnerville, NV
If you have a Digital Volt Ohm Meter, (and you should have!), in the DC volt mode put one lead on the common contact and one lead on the normally open contact of your relay (these should be the leads to the relay contacts, not the relay coil. With the relay energized (turned on) those contacts should be connected to each other with very low resistance and almost zero voltage measured. What voltage do you see across those contacts? If it's a few millivolts, okay. If it's 2 volts, as you say, the relay contacts are bad.
The Stinger relay, as you've read, has a less than stellar reputation, especially when operating in winter weather it seems. I'm using a Bosch 75 amp relay in mine, no problem, but only 'cause I have a bunch of them from other projects. Just get the Cole Hersee and be done with it.
JMynes
JMynes
542
3,230
Augusta, Maine
Yep. Just swap it out. Not worth your time dicky-dicking around trying to get it to work.
And the Stinger is still good for something once it’s removed. You can set it on a berm at 200 yards and see how many times you can hit It before the pieces get too small.
63,664
And you confirmed this by disconnecting it at the post?
Fyi, they are fairly simple to take apart.
nitrotmann
nitrotmann
52
150
  1. 1000 6 Crew
Things to check, thanks.
nitrotmann
nitrotmann
52
150
  1. 1000 6 Crew
The two little low voltage terminals have 0 v between them when activated by key on.
It'll be a week or two before I can get a replacement, so I'll got back through and make sure everything is hooked up correctly.
63,664
??? I'm not sure your doing this right... or maybe you said it wrong?
Because
The small post require 12v to activate the contactor. If you are testing 0v "when activated" then something is wrong with your testing method or setup.
Reactions: WagginTail
nitrotmann
nitrotmann
52
150
  1. 1000 6 Crew
I don't believe the stinger was working properly. I took it out and opened it up. Things moved freely, so I put it back together.
Reinstalled it and now everything works as it should. I don't know what happened to make that happen.
Thanks for the advice. Cole Hersee to be installed when I can get one.
