Multi Strapping down your SxS
103,611
Ericsson’s (?) on spelling...one on each tire with wheel Chocks and one big ratchet strap behind. Plus I run a locking cable through the trailer rails, ramps and behind the front bumper of the P5. I’m not taking any chances with no rear gate.
11B4B1CC BBFB 4702 8312 07FDA8C4F06F
Jamesgang
Jamesgang
148
297
Kitzmiller, Maryland
View attachment 89659 Been using the Erickson wheel chock setup for over a year now. Best method I've ever used. Just got back from a 3600 mile trip and never had any issues with straps loosening.
I use the same thing. Other then I only have them on the front. I've use them for over a year now with no issues. I used metal angle under the deck that spanned over two boards. would need to break both boards to come off.
Reactions: ohanacreek
rtn001
rtn001
317
945
Central Florida
I may when I get an enclosed.. I’m thinking etrack and possible over the tire
I also went with the Erickson chocks and straps and they work great. I would go with the E-track now as I transported my son's Rubicon and could only tie dowm the rear tires as his wheel base is shorter. On the way over I straped the front and the rear end of the bike bounced to the right side of the trailer due to the steering. On the way home i straped the rear and you don't have that problem. After getting the Erickson I talked with a friend who uses E-track. His bike fits the E-track and he is able to strap all four tires. His son's bike is narrower so he puts the right side tires on the E-track and straps the front and rear tires. He hasn't had any problems using this system.
20181017 132119
Reactions: Shadesmn
K
kukini
40
90
Maine
Your other option is purchase the Erickson setup with chocks. You will be drilling 12 holes per wheel to mount.
Or keep doing it as you are now.
I bought a set of the Erickson over the wheel chocks, I never installed them, Just couldn't bring myself to start drilling thru the floor of my trailer either.
I use the Erickson system and it's worked very well all season. I would never tow without it or a similar system again.
44475355 10218331858507297 6227370681307234304 n
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
How well do the tracks work with different width vehicles. If you set it up for a stock pioneer then add offset wheels... do you need to move the tracks? Would assume so? I cant do the erickson system since my pioneer is never in the same place unless its the only thing on the trailer. Will probably just keep using the same method but im gonna look into some of the better straps that have been posted
Reactions: JTW and dnjones161
dnjones161
dnjones161
583
1,712
I'm in the same boat: looks neat but we bought a 20ft carhauler to do it all. Sometimes it's just the Pioneer, sometimes it's the Pioneer and Foreman (or 2). Tracks could work but the chocks wouldnt.
I tie down very similar to @Neohio except in the back I use the hitch as an attachment point rather than the roll cage.
Reactions: JTW and Farmer
Vikes79
Vikes79
SKOL!
10,889
105,616
South Dakota
  2. Talon X4 LV
If you are using straps to the frame and back to the trailer, using an additional bungee strap between the two hooks on your ratchet straps will eliminate the straps coming undone over big bumps and the such.
Farmer
Farmer
2,851
16,389
Southern MO
Yeah I'm in the same boat. Dying to go over the tire but I'm always hauling something different. One time it might be my 700 centered in the middle, one time it might add my small 86 Fourtrax, or sometimes it's a buddies big foreman. Plus I can't convince myself to drill that many etrac holes in my aluminum deck.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I ran e track front to back on my trailer then used special straps made for e track to strap over the tire. It has worked really well. Sometimes I have an extra 4 wheeler in there so I can arrange any way necessary Dc7ae74c78e22ad6b97deb91edda69e4
dnjones161
dnjones161
583
1,712
I ran e track front to back on my trailer then used special straps made for e track to strap over the tire. It has worked really well. Sometimes I have an extra 4 wheeler in there so I can arrange any way necessary View attachment 103924
Drooling at that trailer :)
Do you cover all 4 tires? I looked at the e track a while back but remember thinking it was maybe sketchy weight wise unless I did all 4 tires? It's been a while I may be mis-speaking or I may have misunderstood the weight rating on those etracks.
Do they come with the mounting hardware? Is the weight rating per section? Like so many lbs per ft of track?
Prolly a good question for etrailer lol don't feel obligated to answer if you don't have it fresh on your mind.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,762
183,062
Grand Junction, CO
Are you guys saying I shouldn't just set the brake and consider it secured? Actually I really like my Erickson over the tire tie downs on my sxs trailer and believe it or not the tie down points in the garage of my toy hauler are great.
Reactions: JTW
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I cover the 2 rear tires and put 2 straps on the front bumper. I know a lot of guys just strap the 2 tires and haven't had any issues.
The e track is plenty strong enough just put plenty of screws in and make sure you screw to the framing when possible. I like the track better than the Erickson blocks because of the larger surface area being bolted down.
Reactions: JTW
RedFred1
RedFred1
301
619
North Carolina
The nice part about the new track systems is there are so many devices that can be used in a wide variety of ways. I do agree that if I had an aluminum bed, I may think twice with all the drilling but I believe there is no better way to tie down anything than a properly installed track system.
Rails and straps are all weight rated and installation does affect what the max capacity will be.
FredD
Shadesmn
Shadesmn
505
959
Ramsey, MN
Tracks work great. We ha e them set up on our 16' trailer and they fit my p500 with offset wheels as well as my buddies 570 rzr with stock and aftermarket wheels. You dont need to be perfectly centered on them with the straps being 2" wide they have a bit of room to make them work over the tire width. We try to center up as much as possible but they are never exact, and we've not had any issues in two years of running them. Plus they make other accessories to tie down with like loop rings and such that you could use regular ratchet straps if need be for other sized loads.
Reactions: Dragon21
I carry my mower which is narrower and the over the tire straps are at an angle but they work.
If it’s something very odd I have e-track d-rings that are rated for the max of the track itself and I have a tiedown point every 3-4” instead of random points on the side of the trailer.
So far it has been much better to tie things down with in general.
