16' p1k5. 12,300miles. Stock.
Won't down shift, code 57. (Have service manual)
I know I have a few other posts relating to this issue. Ive read every post relatong to this matter from hear to east-jabib. But I don't know what to do at this point.
I have done: checked all DCT wiring and plugs, replace shift motor wires, and a shift solenoid wire. Removed, cleaned and checked shift motor (bench tested both directions), replaced the 40° angle sensor under the seat. (Fault code 57) Checked batteries, grounds and cleared stored codes. All is good. Will slowly downshift once or twice but quickly flashes a code and stalls from not downshifting. Immediate issue. Happens as soon as I pull out of the driveway
I just don't know what else to check. Could it be the ECU? What about the 2nd shift angle sensor next to the shift motor? But thats a different code. Put a new shift motor in it anyway? Dealer is zero help. I quote; "you've done everything we would've done". Something is broken and I just can't see it. (8k takes it as it sits)
