Hi guys new here, bought a 2018 pioneer 1000-3 with a bad reverse and low gear. So i took the sub transmission out to Repair it. ordered the parts and switched it over to the talon gears. My problem is i cant get it back together. I have rhe honda service manual assembled everything as the manual says, but when i do that i cant get the two halves of the case to tighten up. If i temove some of the washers from the main gear stack i can get the two halves t tighten up. I have tried all sorts of combinations, some cases the halves will seal but then i cant spin the input shaft. I woul assume once everything is back together and in neutral you can spin the input shaft by hand. Any help would be appreciated. I have taken it apart a 100x and verified every part. Im at a loss as to why i would nit be using some washers.
