P1000 Sub transmission issues
Chunk4546
New york
Hi guys new here, bought a 2018 pioneer 1000-3 with a bad reverse and low gear. So i took the sub transmission out to Repair it. ordered the parts and switched it over to the talon gears. My problem is i cant get it back together. I have rhe honda service manual assembled everything as the manual says, but when i do that i cant get the two halves of the case to tighten up. If i temove some of the washers from the main gear stack i can get the two halves t tighten up. I have tried all sorts of combinations, some cases the halves will seal but then i cant spin the input shaft. I woul assume once everything is back together and in neutral you can spin the input shaft by hand. Any help would be appreciated. I have taken it apart a 100x and verified every part. Im at a loss as to why i would nit be using some washers.
Reactions: Lady01 and TxDoc
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
Pictures please of the gear stack
Reactions: Lady01
Chunk4546
New york
Here are some pics.
the pics of inside the sub are of my version to make it work. The pics of the gear stack outside are the way the book says but the last top washer does not make it to the groove.
FE92CEE1 6D93 4458 A8A4 51218D973E25 A34D76AB E613 41D8 8E74 1B4F0280A215 F54B15A0 EBCA 4A6F 9E2A 29D405AE0736 3AE60465 2C1B 4E46 A941 E27F1E238B77 139B7810 6D38 4C30 8574 58644A52A41E B5A58566 6446 4F68 8792 CDC8DA9059FF 2C591C7F 7D45 42D8 8B6E 2EC86B285E89 496BEAFB EE7C 420C 852A 1A2EC68F1AC2
Reactions: Lady01 and TripleB
hondabob
1,161
4,535
Prescott Valley, AZ
Check the collars and washers with the parts book. The Pioneer manual says to assemble it in Park which is impossible. Assemble it in Neutral and check the Talon shop manual.
Chunk4546
New york
I looked at the parts fiche and their is 4 difference between the pioneer and the talon. The reverse idler, the reverse gear, the input shaft itself and the needle bearing that goes in the reverse gear, but that shows as the same size as the pioneer. I was hoping some people that have done the swap would chime in on what they have experienced.
Reactions: Lady01
bigshoe
bigshoe
421
1,425
Are u only using the talon reverse gear?
Reactions: Lady01
Chunk4546
New york
I am using the talon reverse gear and the talon reverse idler gear. do i need to use the talon shaft?
Reactions: Lady01
Chunk4546
New york
I have looked at this to death and cant figure out what is wrong. Does anyone have pictures of the talon gear held next to the pioneer gear. I want to see if maybe i got sent the wrong gear.
Reactions: Lady01
P
patpete
65
149
Alaska
Did you ever get it back together ? I’m about to tear mine down.
Reactions: Lady01
Chunk4546
New york
Yes I ended finding out I had the wrong high gear. When I first took it apart I tossed the original high gear and had put it two low gear. Got the correct gear and no more issues.
