P1000 Sub Transmission Oil Plug Cracked Casing
A
aspire
26
49
ottawa
I have a 2020 Pioneer 1000 EPS and was performing an oil change of the sub transmission and over torqued the oil drain plug cracking the casing around it. Now its a much bigger problem and I am pretty frustrated. I have a paper copy of the service manual but looking for some advice.
Assume I have to remove the sub transmission completely to fix?
Do I need to drain the new engine oil I just put in, in addition, to the sub transmission oil?
Assume I will need these replacement parts to complete job? Anything else?
GASKET, SUB-TRANSMISSION CASE
21206-HL4-003
GASKET, SUB-TRANSMISSION COVER
21205-HL4-003
CASE, SUB-TRANSMISSION
21100-HL4-000
COLLAR PARKING (its cheap and there is a recall so figured i would get one)
24563-HL4-000
Thanks
Reactions: BWAF
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
21206-HL4-003
21206-HL4-003
21100-HL4-000
24563-HL4-000
Thanks
If there is a recall on park collar buy case and let them put new piece in when they do recall !!???
Reactions: ChadD
The recall involves inspecting the collar to see if its missing with a borescope. The sub trans only needs disassembled if the collar is missing, which I haven't seen a missing one yet.
Reactions: ChadD and BWAF
A
aspire
26
49
ottawa
I am also 3 hours away from a dealer without a trailer. I don't mind doing the work myself, just looking for some guidance.
Reactions: JACKAL and ChadD
Hondoman
Hondoman
727
1,695
Texas
Look up the threads on adding the lower talon reverse gears. They show the steps to remove and reinstall the sub trans.
Add the talon gears while you are in there.
A
aspire
26
49
ottawa
Any thoughts on how to transfer the bearings from the old case to the new? The machine is only 6 months old with light usage so the bearings should be in good shape. There are 4 of them to transfer and the bigger one has an oil seal. I don't have the specialized tools or a press. I have seen Youtube videos where a heat gun is used on the case/bearing and then gently knocked out with a mallet and follow a similar process to install.
20210117 181548
Reactions: Mudwing and TripleB
TripleB
TripleB
11,715
99,463
Caryville, Tennessee
How did u crack it?
5,028
22,469
I'd make a puller out of threaded rod. To tap them out, you're hitting the inner race which drives the outer race by impacting the balls, bad juju. A puller is much more gentle. The alum may expand enough when heated for them to drop out but then you have to worry about the one with a seal.
You'll never get the needle bearings removed without destroying them, id count on getting that one. Without a blind bearing puller the smaller ball bearing isn't coming out either.
Reactions: Mudwing and ChadD
tdhanses
tdhanses
1,044
3,553
Kansas
New bearings can’t be that expensive, I’d put in new bearings and get that case fixed for a spare.
A
aspire
26
49
ottawa
Dumb question... since the original case is already broken, what prevents me from taking an angle grinder to the case to free up the bearings?
A
aspire
26
49
ottawa
Fair point... if I go this route, what method should i use to install them?
You'd be pressed to cut them out and not damage them, especially those needle bearings. That and all the metal shrapnel could end up in the bearing and shorten its life drastically.
tdhanses
tdhanses
1,044
3,553
Kansas
You can fix that case, I wouldn’t destroy it.
tdhanses
tdhanses
1,044
3,553
Kansas
If you don’t have the tools to press them in I’d take it to the dealer and have them press the bearings in, take them 10 mins to do probably.
TripleB
TripleB
11,715
99,463
I used a torque wrench to tighten the drain bolt but never heard it click... i kept going and it cracked the case. It was stupid and i should have known better but it is what it is. Now i have a big job to fix...the good news is I will never make this mistake again :)
I'm always messing something up myself..
rickoshea
i stripped mine trying to remove it last oil change.9 ft. lbs? in.lbs maybe.never again with a torque wrench.i only had to buy a new set of metric bolt extractors because of course mine were at the other house.it only cost me 2 new bolts and a jug of oil (because i removed the filter before i undid the drain).
