P500 Super Winch Terra 35 amounted on rear?
JCart
JCart
895
2,021
Kamloops, BC Canada.
Hi Fellas,
Clearing keerap outta my shop and have the spare above winch with all controls etc. Been an awesome winch, had it on the front and used lots for snow ploughing, has developed (or so it seems) noisier on Power wind out, so replaced it with Terra 45 SL. Thinking I’d like to maybe mount it on the rear just for fun. Anyone done this and a have mount, images, or any insights would be great. No hurry just nuther project that I may do at some point.
Thanks,
j
futzin
futzin
4,286
31,760
Kentucky
Post #12 shows a winch with receiver mount in a Moose Receiver.
[/QUOTE]
1583887508247
JCart
JCart
895
2,021
Cool cool thanks fellas, will need to order up a Moose hitch when I get time and make a plate up. Seems easy enough thanks.
j
Mudder
Mudder
NTC Ambassador of Walls
11,690
88,472
j
I like my Moose hitch, but Call Moose when you order and tell them you want the proper bolts and guaranteed free return shipping if not correct. Lots of posts on issues if you search. Worst case is a trip to the hardware store, someone posted the correct bolt size if you need them.
Reactions: JCart and trigger
182,036
You know, the more I've thought about it, you're right. The bottom bolts worked but they aren't 10mm like they should be. Those are A arm bolts and there should be no slop whatsoever. Good call Mudder, I'll be changing mine out.
Reactions: Mudder and JCart
Hmmm, seems odd that they still haven’t fixed that....🤔
Reactions: Mudder
futzin
futzin
4,286
31,760
Kentucky
Problems also exist with the hole alignment. Several folks, including me, have had to ream out the holes.
Reactions: Mudder
