Anyone have any issues open trailering at prolonged highway speeds with the windshield installed?
No, I've trailered 9+ hours at a time at 75-80 mph multiple times. Make sure it's latched.Anyone have any issues open trailering at prolonged highway speeds with the windshield installed?
I’ve had it happen once but then I adjusted it and used lock tight on the screws. Hasn’t happened since.While we’re on the subject of SATV flip up windshields, does anyone else have problems with theirs rattling? I’ve loosened and readjusted mine a half dozen times now and I can’t get it to stop rattling where the two halves meet. It’s annoying enough (especially at idle) that I just leave it cracked open now. Buddy bought one for his Wolverine last year and it came with 2 latches on the sides instead of one in the center like mine has. Wish mine was set up like that, I wouldn’t have this problem!
No issues, I just keep it at 75 or below and it’s fine.Anyone have any issues open trailering at prolonged highway speeds with the windshield installed?
I know of 4 of these windshields that rattle! We have tried several tricks with adjustments and they all still rattle! But still love the ability to open/close!While we’re on the subject of SATV flip up windshields, does anyone else have problems with theirs rattling? I’ve loosened and readjusted mine a half dozen times now and I can’t get it to stop rattling where the two halves meet. It’s annoying enough (especially at idle) that I just leave it cracked open now. Buddy bought one for his Wolverine last year and it came with 2 latches on the sides instead of one in the center like mine has. Wish mine was set up like that, I wouldn’t have this problem!
Adjust the windshield so that the two surfaces match up nicely and then adjust your latch. If you can’t get it to stop by doing that then you’ll need to add another seal strip between the upper and bottom sections.I know of 4 of these windshields that rattle! We have tried several tricks with adjustments and they all still rattle! But still love the ability to open/close!
Yes Sir, been there and did that. We were able to reduce the rattling by installing some washers at the top of the lwr half to make the windshield protrude outward. Would love to hear about anymore suggestions!!!!!Adjust the windshield so that the two surfaces match up nicely and then adjust your latch. If you can’t get it to stop by doing that then you’ll need to add another seal strip between the upper and bottom sections.
I’ll try to get a few pics in a bit.Yes Sir, been there and did that. We were able to reduce the rattling by installing some washers at the top of the lwr half to make the windshield protrude outward. Would love to hear about anymore suggestions!!!!!
Mine does not rub at all.One other issue to look for. If you have the Honda hard top/roof.......you might want to make sure the windshield doesn’t rub (in the up or fully open) on the hard top!
Mine does the same thing. I latch it tight but that only works for the center. The side flap around pretty easily. I rotated the clamps to try to put more pressure on it, no luck. Kinda sad and frustratingWhile we’re on the subject of SATV flip up windshields, does anyone else have problems with theirs rattling? I’ve loosened and readjusted mine a half dozen times now and I can’t get it to stop rattling where the two halves meet. It’s annoying enough (especially at idle) that I just leave it cracked open now. Buddy bought one for his Wolverine last year and it came with 2 latches on the sides instead of one in the center like mine has. Wish mine was set up like that, I wouldn’t have this problem!
Here are a few pics of mine, no rattles after I got it adjusted.One other issue to look for. If you have the Honda hard top/roof.......you might want to make sure the windshield doesn’t rub (in the up or fully open) on the hard top!
