Talon storage options poll
Which storage option listed below would you most like to see made avaible for purchase?
  • X4 rear seat aluminum replacement expedition style box, full opening lid (XL capacity)
    Votes: 0 0.0%
  • Total voters
    14
  • Poll closed .
highpocket74
highpocket74
2,171
7,194
Kinder, Louisiana
www.10-80dirtsports.com
Well, I miscounted my hatch lid inventory so I’m ordering more. I didn’t realized I’d used that many. Website will show out of stock on cargo box kits. However if anyone is interested in a kit I can ship the metal components now and follow up with the hatch lids. That’s the last item for assembly anyway.
Reactions: Montecresto
highpocket74
highpocket74
2,171
7,194
Kinder, Louisiana
Update on hatch lids:
Placed the order this morning and should have these around June 21. The supplier is FAST! This is the only item I import for the cargo boxes because I haven't found this style from a US manufacturer. I tried a screw in type hatch that I could order from Dallas, TX but I didn't like those in 4" and 6" wouldn't work. The lever style works perfectly for easy open and close in the location.
Sheetmetalfab
Sheetmetalfab
2,454
15,682
Alaska
Finally got around to welding one up.
it’s been over a year since i did much Tig welding so I’m a little rusty.
Fitment is excellent.
lots of tape. 😁
FF563F36 3FE5 4F17 B13D B589B987178B
8AB94B9B C0F6 4F37 8260 19EF68A361E0
05E24675 6907 4D6F 9B3E BB634EC8EF61
D9F48D65 75CE 41E2 856F 9E5F4927A051
highpocket74
highpocket74
2,171
7,194
Kinder, Louisiana
Send another X4-p box to powder coat today. I'm excited that my TIG skills have greatly improved in less than 1 bottle of argon! Thought I would have more welded up but life interrupted.
Having a few more boxes laser cut today also. I have to tag on when the shop cuts aluminum because it may be several weeks before the next aluminum run.
Reactions: Sheetmetalfab
Sheetmetalfab
Sheetmetalfab
2,454
15,682
Alaska
Sheetmetalfab
Sheetmetalfab
2,454
15,682
Alaska
So everyone knows.
I put the entire list below in the passenger storage box of my talon x4.
4 spare Brake lines (ss braided to fit portals)
Pint Brake fluid
Quart Portal blood
2 Oem Tie rods and outers
2 oem Inner tie rod ends
2 Hd outer tie rod ends
2 upper Ball joints
2 Satv ball joints lower
Elec tape
Shock adjustment tool
Oil and dct filters
Big and small zip ties
Small syringe
Portal shaft nut socket
Lithium ion Jumpstart pack
Wired Winch controller
Spare winch contactor
3 sizes of Hose clamps
3 kitchen hand towels
Reactions: Mudwing
Sheetmetalfab
Sheetmetalfab
2,454
15,682
Alaska
Drivers side box has 10 each 16 oz water bottles inside.
811C3870 8021 4C54 8D80 457BF162BECD
6A40EBA8 3EB3 4E85 894A A311C6819091
576D66D8 DE74 493D B162 25ECC8B3FB13
Reactions: Mudwing
sandbaja
sandbaja
130
421
San Diego, CA
  1. Talon R LV
  2. Talon X4 LV
So everyone knows.
Pint Brake fluid
Quart Portal blood
2 upper Ball joints
Elec tape
Oil and dct filters
Small syringe
Impressive!
highpocket74
highpocket74
2,171
7,194
Kinder, Louisiana
These are ready to go to powder coat the week of sept 20. I’m getting much better and faster with the TIG welder and the technique.
FF3C2B84 75FD 494E 8B18 BFE2E9F00221
These will be ready to purchase after powder coat in 2 weeks. I’ve stated on my website listings that if you want one then you can purchase ahead of time and I’ll put your name on one till they are ready to ship. That’s not a problem.
More will be ready to weld up about the time these come back from powder coat. I have to fall into the shop schedule of when they cut aluminum. A little inconvenient but the laser cut is so accurate that’s it’s worth it.
highpocket74
highpocket74
2,171
7,194
Kinder, Louisiana
If you want a cargo box and can paint or powder coat yourself or have it done locally, I’ll knock $20 of the price for an unpainted but otherwise complete box.
send me a message and I’ll setup the invoice.
Sheetmetalfab
Sheetmetalfab
2,454
15,682
Alaska
Sincere question.
why are you coating the aluminum boxes?
no corrosion, they look good as is?
highpocket74
highpocket74
2,171
7,194
Kinder, Louisiana
Sincere question.
Mainly because the aluminum always has surface scratches from the automated loading and unloading in and out of the laser cutter. There is no way to avoid this. I don’t like selling them like that as a finished product because it doesn’t look good.
