Talon X4- 4” portals 30% reduction
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
Rears on and brakes bled.
3F1B0F32 AD8C 45CC B1AF 544A79027E19
5B78769D 2BD9 4D6E 9F34 93E73041F6B2
gotta swap my 6-1 wheels out for 5-2 if I cannot find spacers locally. (I already have the 5-2 wheels but they don’t match exactly)
TMCCOY
27
34
Looks great, why the need for 5/2? Interested to see how it drives for you. Are you doing anything for speedo or ABS correction?
Reactions: Mopower58
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
The tire / wheel hits the portal backer plate with 14” wheels.
22’s might clear in 6-1 offset.
I’m running a PV3 tuner with canned tune from dynojet. (Happy with it so far)
Mopower58
Mopower58
CST is the Best!
70,052
643,656
Crystal Springs,Ms.
Looks good, and wide! Let us know how she does.
TMCCOY
27
34
Well, looking forward to hearing how it drives, in particular the handling with the scrub radius being impacted greatly.
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
First ride,
The geardown helps immensely with shifting, power on tap and crawl ability.
(this is how it should be shifting all the time) = better than stock W 28’s in auto.
Quite a bit More feedback through the steering wheel.
(potentially enough to consider a sandcast rack and stabilizer and or larger power steering unit)
Small bump compliance definitely diminished (slightly)
Big bump compliance is still very good.
ITS A BEAST!
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
First ride,
ITS A BEAST!
Rode Saturday and actually tore some muscles in my shoulder from the steering wheel getting blown out of my hands when going fast across rough tundra.
So I bought the EPowersteering.com kit.
Got here today, installed it this afternoon, tested it just now.
Works amazing.
Steering effort is lower than stock PS without the portals.
Less feedback through the wheel also.
E8AFD829 DA7C 4C1E A3AB 958E2926B8E6
190B5049 6478 4D0C 8C88 C2DB4ED6F936
8ADFD2BD B0E1 465C B02E A20484EE7B66
TMCCOY
27
34
Let us know the improvement you find with the new powersteering after a trail ride, curious to see how it works on the trail.
DDDonkey
Bottom line.
If you want portals?
Plan on buying the PS upgrade at the same time.
Interesting you say this, I wonder if the Talon has a lower powered, power steering motor than the Pioneer, or if yours was just weak? I have no issues turning 35" with my stock unit in my Pioneer unless in 4 low with the front diff locked.
Thanks for the pics and you have a great looking rig! Let us know how the install going and any issues you may run into.
Sheetmetalfab
Sheetmetalfab
2,017
12,311
Alaska
The stock ps motor turns them fine.
Slow speed is no problem.
Trails are no problem.
Fast speed the PS unit overheats (happens After about 300 yards of high speed tundra)
Imagine “tundra” as being volkswagon size boulders covered in moss.
Ultimate traction, tires grab and pull back and forth as you go through.
I want to be able to go 25 mph through them like i did without the portals. (It was no problem before)
This steering upgrade definitely helps that ability.
In testing i ran 15 mph over 12-16” logs at a 45 degree angle. Only a minor bump in the steering wheel with one hand holding it.
^^^^that was my goal.........
