Talon1000x4 rear wheels crooked
SLOWPOKE693
SLOWPOKE693
1,639
6,278
Somewhere in Texas
Swap both factory radius arms left to right and see if that changes anything. If the problem swaps sides with the arm swap you will have found your bent part. If it doesn't, you now know the trailing arm is potentially bent.
207,989
Did anyone ask him if both rear wheels were toed out or just the drivers side? I couldn't get his pictures to load.
Reactions: JenElio
W
Willt1977
25
34
Kettering ohio
  1. Talon X4 LV
That's a good idea. Thanks
Reactions: JenElio
207,989
I have a 2020 talon1000x4 and recently noticed that the back wheels were kicked out in the front. Have heard it is possibly a blown shock. Anyone have this issue
Can you post a picture of the passenger side rear wheel, is it towed out as well?
Reactions: JenElio
W
Willt1977
25
34
Kettering ohio
  1. Talon X4 LV
He never said and no one asked. His single picture only shows the RR tire.
It is slightly
I believe it is but not as much as rr.
Screenshot 20220104 213811 Gallery
Reactions: JenElio
W
Willt1977
25
34
Kettering ohio
  1. Talon X4 LV
I have not. Just have the back ones on. Working on the front ones this week. View attachment 311817
Although I don't believe it has anything to do with the Portals as it was toed before I even started installing portals. When I was installing them I had a hard time getting the radius arms to line back up to reinstall. The left side radius arms went right on, no problem
Reactions: JenElio
207,989
The portals have probably have nothing to do with the toe out, you aren't ready to deal with camber yet.
Reactions: JenElio
207,989
Not sure why the photo isn't showing up. O attached it to the reply
Me either, so tell me the right & left side look the same or is it just the left side.
Reactions: JenElio
