Talon1000x4 rear wheels crooked
207,989
We're u able to see photo yet
Nope.
Well the passenger side can probably be taken care of with radius arm adjustment, the drivers side you have something bent. SATV has an excellent instructional video for installing the A-arms, that does a great job of explaining alignment procedures front and rear, you have a different rear set up but the principles apply. You should watch it about 3 times, that's how many times I watched it. Don't pay attention on how to adjust there A-arms, just the principles of alignment.
Reactions: JenElio
W
Willt1977
25
34
Kettering ohio
  1. Talon X4 LV
Nope.
Not sure the radius arms are adjustable
Reactions: JenElio
WilliamRamey
WilliamRamey
7
KY
Bent a trailing arm in a roll-over. Straightened it out using a 20-ton press and a pattern made form the bottom side of the other trailing arm.
Reactions: Willt1977
W
Willt1977
25
34
Kettering ohio
  1. Talon X4 LV
It is slightly
I believe it is but not as much as rr.
16414069092454628544618607165846
906UP
906UP
13,098
122,261
da Yoop
Although I don't believe it has anything to do with the Portals as it was toed before I even started installing portals. When I was installing them I had a hard time getting the radius arms to line back up to reinstall. The left side radius arms went right on, no problem
There's your clue, something on the RR is bent, if you swap the radius rods and see no change then it has to be the trailing arm, there are no other components unless you somehow bent the knuckle but it's highly unlikely.
Reactions: CID
W
Willt1977
25
34
Kettering ohio
  1. Talon X4 LV
Put new knuckle on with portal install
Hometeam
Hometeam
942
3,733
Normal, IL
I have not seen a photo on the thread since I responded earlier today
Crazy....I think every photo has come up for me.
From the picture of the driver side, I don't think that side is bent but its hard to tell from that angle. A picture from the entire back, along with one from the back going down each side would tell us a lot. If its a radius rod you see that real easily. I bet that it is ever so slightly bent on the trailing arm at the angle bend that heads towards the wheel.
906UP
906UP
13,098
122,261
da Yoop
This new software platform is strange. Ill look at this thread later from my laptop and see if there's a difference.
Reactions: Hometeam
NTCPrezJB
NTCPrezJB
President of #NTC
101,347
905,282
Canton, OH
I see them on my phone browser for whatever it’s worth. #TuckFapatalk
906UP
906UP
13,098
122,261
da Yoop
Still no pics on my laptop. Regardless the easiest way to find out if you really have a problem is to measure with a tape, in front of the wheels and in behind the wheels. They should be the same. Take a couple straight edges (2x4s work good) and couple ratchet straps, then attach them to the wheels, measure on both sides.
Reactions: Hometeam
