P1000 tdhanses build - snowflake
tdhanses
tdhanses
1,044
3,553
Kansas
Man changing shocks is so quick and easy, threw the fronts on really quick tonight.
556FF000 D429 44FC 9DC0 7AFEE59C0F88
AA89A7ED 66F9 4AF3 BAC4 314065F85066
Sr56
96
284
Murfreesboro
Nice looking build so far! Now time to get some dirt on that clean white ride!
Can you tell me about the floor jack / lift you are using?
Thanks!
tdhanses
tdhanses
1,044
3,553
Kansas
Thanks!
Getting close, still need to install winch, new front bumper, skid plate, dual battery and some storage. Was also hoping to get the plastics wrapped but we’ll see if that ever arrives.
Here is the jack 1500 lb. Aluminum ATV / Motorcycle Lift I really like it and it automatically locks in the up position as you go up so it can’t just drop, have to unlock it to lower it.
Reactions: EMAW
tdhanses
tdhanses
1,044
3,553
Kansas
Spent the morning doing the gig that pays the bills but spent the afternoon working on snowflake since the kids are at their moms.
Installed the winch and only ran the blue and yellow wires, will wait to wire it all up once my battery shows up. Also removed the hondasxs front light bar from the stock bumper, just to remount it on the LE front bumper. Also took the time to adjust the rear diff, it was slightly out of adjustment.
Not sure on the placement of the winch solenoid but it fits super tight in the spot it’s in and doesn’t interfere with the hood. Also not sure about the light bar placement but I don’t want to put it below the top bar and didnt really like it above it but might remount it and see what I think.
ED308430 C4DD 4C44 AF17 2CB7B6821E2F
37F5F18A A082 4FE7 A68E 26A54E20C52B
6F21B34F 5D94 47C4 B41C 189267A5327A
3A9A7166 8575 424C 92E9 79A7FB433A80
1B53E636 C59E 4DF5 B903 35C089643803
tdhanses
tdhanses
1,044
3,553
Kansas
Today was a day of storage mods, the throttle max and rear view mirror. The Amazon made in China drink holders mounted up perfect, wasn’t too sad/concerned going with these as they probably make the Honda brand holders for Honda.
BBC8DB57 B861 45A3 ACEA 9E08588A51A2
BE502F34 22CB 4173 AD66 049F0698F08E
DE87364A FB5E 46CC 9EAC 1A41E8874A4B
52F61C2A 59EB 46BB AA75 A580C419BFB7
E8937244 2B37 4123 9F20 D53486C977FE
57F5101B E744 415A A29E A8F52428BF32
A16C597E 2054 4A00 98FE 5132D14CDCC5
7C2775B7 3B19 4AF8 8724 E74561377199
A3C3E5DB ADDB 490F ADC4 7387947B2A45
tdhanses
tdhanses
1,044
3,553
Kansas
Skipped fooseball and instead went to installing the SATV skid plate and frame stiffener. I was wondering if the skid plate would be a pia if I didn’t put my utv on its side, naw it’s not bad at all to crawl under and just hold up as you go. Might help that the SATV skid plate comes in 4 pieces.
3115B8F1 0ED9 4A48 87F6 06DB88D96621
86902642 A416 4FF7 8F8E 032746BC9D94
92A661A8 F368 4942 86B9 A8A28EDE9985
6E7E614F D667 4DC2 A6E1 587A5F48BD73
TripleB
TripleB
11,842
100,440
Caryville, Tennessee
tdhanses
tdhanses
1,044
3,553
Kansas
Does the skid completely cover the frame stiffener?
It would, you have to cut that part off if using the frame stiffener. I had asked them before hand and that was what they said to do, now I think if you really wanted it you could mount it without removing but really I saw no need with the stiffener on, it is very stout and protective.
tdhanses
tdhanses
1,044
3,553
Kansas
Started on the second battery and placing everything. I think these spots will allow for a clean look and are the common areas most mount them, stole @Russ989 idea on the fuse box mounting area, used the plastic I cut out of the rear door for storage for it.
9A5E0C67 5392 44B7 91A3 F64A956F1D88
4B1EBFFD 31D7 4A33 8B66 6FA50870EC4A
7F7A1B75 799B 4ABA BD9C 344A5E6D9C09
Russ989
Russ989
22,588
146,738
207,989
View attachment 243690View attachment 243691View attachment 243692
That's where I mounted the fuse panel, I was a little concerned about battery replacement, I routed the wires where I had some slack and secured with zip ties, when I replaced the battery, cut a couple zip ties and flopped it outta the way. Looks good!
Reactions: EMAW and tdhanses
tdhanses
tdhanses
1,044
3,553
Kansas
That’s exactly what I was thinking I would do.
tdhanses
tdhanses
1,044
3,553
Kansas
Was able to get a little more wiring done today, true isolator is working perfect, stays lit blue for maybe a min max then you can hear it click off. I did a test fit of the air box, it still fits without issue.
Winch and Fuse box are wired off the stinger, this ok? I also wired the factory winch ground to a common bussbar. I’m going to prewire the battery tonight so it’s easy to just connect it once I’m ready. Think I’ll do the switch plate next and need to wire in the fan override plus waiting for the backup light override.
Let me know if you guys see any issues with it so far.
477992A0 A36F 4D3E 9270 B4724EADAA94
47AAEF35 5A47 4489 8806 1AB3F0D056D2
EAF6F6A5 4016 4E4B 9DE6 7C6C54BF57D6
03730909 3244 4541 B946 A1C32D92C9F0
tdhanses
tdhanses
1,044
3,553
Kansas
Also on another note, are all of the pioneers hard to start when cold, mine actually fired up then died and backfired first startup, second one it started right up. I’ve notice as it has been cooling off it hasn’t fired up as fast as when warm out.
Also having the intake closed up with the glove maybe didn’t help 😂
