P500 The Mini Beast
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Plastic clips for the shield are due to arrive today. Can't wait to try them out and hope they fit like you said? I don't really have a problem with the shield blowing back or anything but it will be nice to have something to hold it together where I cut around my snorkel pipe.
Thanks again!
Believe me they are very tight around the TriggerShield...assuming the same thickness of material.
Reactions: rtn001 and trigger
Eltobgi
Eltobgi
4,599
15,186
North Dakota
765BE251 CEAB 4648 A39D C22E3A10FE58
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Fronts install and comparison...
39BB55F3 7FD6 4337 84C3 3A29E3710AF1 898FD131 F09E 44E2 B74A D80A180B50F4 260488EA 29BA 48B4 9B4C 5BC205C383CD 703816BA 22D1 4E7E 9A0E EFDE5BA7B3EA 4EA4EDFB BEE9 4067 B252 088412BB3918
On these install pics I mounted the reservoirs forward against the instructions which is to mount them with reservoirs to the rear.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Huge improvement just messing with setting now. With all four on softest setting you can feel a little body roll at about 20 mph and that was on hard pack. Will need a little more time to find the sweet spot for quick running! At this point I can say ride comfort has drastically improved!
They are sexy little b****es!:cool: Very pleased!:)
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Had to take mine all apart to have black springs, those look BA! :cool:
Thanks, the wallet is still hurting but the pain is lessened with each ride! Have them set 5 clicks from softest and the still feel so comfortable! Going to set them to the center setting (15 clicks) tomorrow and run them hard and make adjustments on the trail.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Had a buddy stop at the house this morning having problems with his Popo. He asked that I follow him to a shop in Rolla and although I already had the 1000 out I thought it was a good opportunity to test the Elka’s:cool:
Still at five clicks all the way around I first thought I would just test comfort and take it easy so I didn’t make any adjustments. Everything felt good and I found myself pushing it further and further until the Mini BEAST was running wide open! In two wheel drive the back end was loose but I kept pushing her! All I can say is WOW!!!!
Jumping a few approaches I did find the bottom one time but still have a lot of adjustment to go! Next test will be 10 clicks front and staying with 5 rear for now!:)
Reactions: trigger and Mudwing
155,598
That's awesome! Definitely seems like the faster you go the more difference they make, I've found myself running faster lately too...don't know if that's good or bad? o_O
Eltobgi
Eltobgi
4,599
15,186
North Dakota
It feels so right it can’t be wrong, lol:cool: But I do have to say the fun factor is elevated to a whole other level!:)
JCart
JCart
897
2,024
Kamloops, BC Canada.
Glad you like them.... hard to believe they make that much difference and with radials, man ride so nice at 5 psi tire pressure. I’ve not made time to mess with the adjustments on mine.
Cheers, happy riding.
jrc
Eltobgi
Eltobgi
4,599
15,186
North Dakota
jrc
Haven’t adjusted mine either. Tire pressure at about 7 psi, and set five click from softest setting. Haven’t had time to test ride at stiffest setting, but still real curious, lol. Soon;)
Reactions: JCart and Tigermark
208,011
I aways get tickled by the guys saying they bottomed there shocks out and want to go stiffer, if your not bottoming your shocks out on the hardest hits, you need to bottom out on hard hits or else your not using all the shock. Only you know how hard to it it, HA!
Reactions: Eltobgi
